Wo ist die Rennstrecke?
DonE's Avatar
G50/03 conversion in a 79 930
What needs to be done to fit this transmission into a 79 930? I know the bell housing needs to be shortened, but what about the front mount? I do not want to cut the car or mess with the torsion bar assembly.
I already have the plumbing, pedal kit, slave/master cylinders, etc.
Will this tranny fit this car?
Old 02-20-2006, 07:27 AM
Hi Don,
I think that is a G50 from a 87-89 Carrera, correct? If so it should fit no problem. You will need to dissasemble the tranny completely. Mach the belhousing and input shaft. You will have to mod the shifter coupler also.
When I did my conversion I used my old 915 front mount and redrilled hole for the tranny.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 02-20-2006, 06:37 PM
The G50.03 was used in the model 964 from MY90 onward, the G50.01 and G50.02 were used between 1987-1989. I'm looking for a G50.03 bellhousing if you know anyone selling.
Old 02-20-2006, 07:46 PM
BReyes's Avatar
Don. Are you doing it now because the 915 is gone? Or for better shifting. I recall a big difference from my G50 to 915(1983 SC).
p.s Is your 915 different internally than SC915?
Regards,
Bernard
Old 02-24-2006, 08:34 AM
resident samsquamch
sand_man's Avatar
Regards,
I'd be surprised if Don was using a 915 with the type of power his engine makes. He's probably looking to replace the four speed 930...
-jeff
Old 02-24-2006, 11:02 AM
BReyes's Avatar
right. I had a question to ask here. Lets see...
Don. Is 4 sp going. If so what is happening to it. Will you be going with stock g50.
Regards,
Bernard
Old 02-24-2006, 12:29 PM
DonE's Avatar
Bernard - I've decided to keep my 930 4sp box since the cost of upgrading to the G50 is so expensive.
Old 02-24-2006, 08:48 PM
