My 76 911S smokes after sitting 1 week
I have a 76 911S with about 68K miles on it. The engine is almost original. The only upgrade is the pop off valve. If I let the car sit for about a week, it smokes a lot for about 10 minutes when I first start it. Then it stops smoking and I don't see any more smoke. It passed the emissions test a few weeks ago.
After reading some of the posts here, I'm guessing it's the valve guides. Do you think I could just rebuild the top end ? Should I do some upgrades at the same time, do a complete overhaul or try to find a good used newer engine ? Any good suggestions would be appreciated. Thanks |
You don't need to rebuild your engine, you need to drive your car more. When your car sits the oil drains from the tank into the engine. The oil then seeps through the rings into the cylinders. When you start the engine the oil burns until it's gone.
What is your oil consumption? Until your oil consumption exceeds 1 quart per 800 miles your valve guides are still probably OK. 10 minutes is kind of excessive for the start-up oil smoke, is it really that long? -Andy
72 Carrera RS replica, Spec 911 racer |
Re: My 76 911S smokes after sitting 1 week
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Mike:
Sorry to dig up an old thread but, my rebuilt '76 2.7L [rebuilt ~80-90k ago] does the same think with 160K on the odometer. Has gotten worse over time but total oil consumption isn't 1 quart per 500 miles. Mine is more like 1 quart every 800 miles. Give us an update ... gotten better? worse? oil consumption? TIA Jason |
Air Medal or two
Just picture 10 to 11 qts in the bottom of the engine at start up.......
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
