LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Case sealant
I was wondering if this stuff (loctite 515) might work as a case sealant?
http://tds.loctite.com/tds5/docs/515-EN.pdf
I got a free tube off of my dad who says that they use this at his job and swear by it like it's the next best thing to sliced bread. From reading through the data it would seem that it's very forgiving of uneven surfaces with gaps (allows up to .25mm gap without an activator !!!) However there is info on those sheets that i don't understand as well which is why i'm asking. Here's 574's tech sheet for reference.
http://tds.loctite.com/tds5/docs/574-EN.pdf
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 03-08-2006, 04:17 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
At 100 deg C you're down to 25% strength on the 515 compared to almost 70% of the 574 - that does not sound too promissing with engines at operating temperatures around 90 - 110 deg C. Why take chances?
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-08-2006, 04:42 PM
syncroid's Avatar
I have been using Loctite #518 for several years now. It is wonderfull stuff! I use it on case halves and cam towers. http://www.loctite.be/eu/PRODUCTS/518.htm
One of the other guys in the shop has experimented a couple times using Honda Bond. http://powersports.honda.com/the_goods/parts_and_service/detail.asp?ProductGroup=Assembly+%26+Repair&PartId=08718-0001&PartValue=Hondabond+HT&TheGoodsDir=2&bhcp=1
We have not tried it on cam towers yet but on the case halves it works really good.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 03-08-2006, 05:44 PM
1fastredsc's Avatar
Looks like locktite 574 has the best heat to strength rating, however 518 has a better gap filling abilities with up to .5mm gap filling. I'm wondering though how much shearing strength a case sealant would need, it would seem that not much sealant surface area is in contact with pressure to cause significant force and in turn some decent shearing loads.
2007 Mazda 3 hatch
Old 03-08-2006, 07:17 PM
Try not, Do or Do not
Henry Schmidt's Avatar
ThreeBond 1104, in conjuction with TB 1211 and Loctite 574.
Ciril T on the cylinder bases.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-08-2006, 08:36 PM
stevepaa's Avatar
I used 518 on case halves, dow 730 on cam towers, and a very light curil bead on nose of #8 and other seals. Also used o-ring lube on all o-rings. 4Kmiles and no leaks
steve
old rocket inguneer
Old 03-08-2006, 09:19 PM
1fastredsc's Avatar
Thanks for reminding me of threebond henry, i had forgotten about that, going to find some data sheets on that stuff right now. I've never heard of dow 730, going to see if i can find that one, thanks.
Edit: I remember reading that you put threebond on the case perimeter with 574 on the crank webs, why not threebond everywhere?
2007 Mazda 3 hatch
Old 03-08-2006, 10:34 PM
We have tried many different combinations and as of now, what we do with sealants has proven to be the best.
No theories, just practical experience.
Hundreds of engines, plenty of mistakes and 30 years later we seem to have it right.
Will other products in other combinations work? sure
But we guarantee no leaks and we can't take any chances.
Henry Schmidt
Ph: 760-728-3062
Old 03-09-2006, 05:49 AM
1fastredsc's Avatar
Cool, i guess i know where i'll go with the sealants.
2007 Mazda 3 hatch
Old 03-09-2006, 08:36 AM
kirkf's Avatar
What is the recommendation for the through bolt O-Rings on a 3.6?
Kirk
1989 911 Carrera 4 (964)
Old 03-09-2006, 04:43 PM
ischmitz's Avatar
I used Hylomar and it does not leak 15k miles later
Old 03-09-2006, 04:51 PM
