964 Cams question
Hello guys,
Just a quickie :
Will the cams from 1992 3.6 engine fit a 1988 3,2 w/o modifications ?
Thanks!
Old 02-09-2008, 10:09 AM
KTL KTL is online now
Schleprock
KTL's Avatar
You can use a factory 964 cam in the 3.2 but you have to grind off the power steering pump gear that's on the cam end. For not much more than the price of a used set of 964 cams, you can get your stock 3.2 cams reground to 964 profile.
Good topic here
964 cams with a 3.2 Carrera
Kevin L
'86 Carrera "Larry"
Old 02-09-2008, 11:35 AM
