Less brakes, more gas!
euro911sc's Avatar
General Stud Nut question...
...and I ain't talkin' horses...
Aftermarket studs have no height concerns because they use a different nut that is open endded vs. the oem that is capped. So why can't I use an open endded nut on a factory stud and not have to worry about setting the height so exactly?
Best regards,
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-03-2006, 10:04 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I don't know the absolute correct answer to this, but if i had to guess, i'd assume that no one makes air-craft quality 12point nuts in our threads size and pitch.
I could also be because of changes in the strain-torque relationship with using a nut other than that of the factory one.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 04-03-2006, 11:19 AM
That would work fine assuming they are the same size and pitch. The OEM are not capped by the way.
Old 04-03-2006, 11:43 AM
Irrationally exuberant
ChrisBennet's Avatar
I've used reduce wrench size nuts (10mm nuts with 15mm wrench size) for the head studs in this application to clear the lower plugs. I don't know if it's recommended however.
Getting the head stud height correct is not very difficult. Heck, even I can do it Mike.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-03-2006, 11:51 AM
euro911sc's Avatar
Hey, if Chris 'It's not my car...' Bennet can do it then anyone can!
Actually, I just seem to be seeing all these posts on stud height issuses every week or two so I was just curious. I mean, it sounds easy enough, but it also seems to be one of the more frequently asked question... that, cam timing, and 'Is this part X re-usable?' seem to be frequent (no scientific data or intelligent design to back it up though).
Just a thought
-michael
Michael
'13 Cayenne GTS
Old 04-03-2006, 12:54 PM
3.4 Bigger is better
88-diamondblue's Avatar
I think that ARP has the 12-point nuts for the head studs. I'm sure they are not cheap but are available. Here are the part numbers for the nuts. There are more sizes available, the link to the catalog supplement is below. Go to page 4.
400-8344 M10 x 1.250 M12 wrenching SS 12-pt nut kit
400-8345 M10 x 1.500 M12 wrenching SS 12-pt nut kit
ARP 2006 catalog
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 04-03-2006, 08:18 PM
