What sealant to use for oil pressure sender?
Help!
My 964 C2 oil pressure sender is leaking. I am chaning the o-ring seal. In addition, what sealant should I use to prevent further leak? Locktite 574? Curil-T? Gasket maker? I am thinking of putting the sealant on the mating surface of the sender to the block. See pics. thanks, anthony |
Try not, Do or Do not
No sealant is necessary. Clean as well as possible and install a new Viton seal.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry. But what is bothering me is that it was a new (non-Viton) o-ring I put in during my rebuild last year.
Is there any extra step I can take to prevent leak? anthony |
In over 25 years I have never used a sealant on that oring fitting.
I just lubed up the O ring and inserted without any sealant...its pretty hard to seal that up and the O ring is nice and fat anyways....
Mike 97 993TT Arena Red - "Scarlett" |
I'll try with just the o-ring.
--- anthony |
