As a side note, the ARP stretch gauge I have will not be used all that often. If someone wants to use it and pay the shipping, they are welcome to it. A paypal deposit (refundable on return) is all it would take! Let me know if this is of interest to anyone.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Super Moderator
Nice offer Jeff!
Wo ist die Rennstrecke?
Stretch gauge
Whoops - meant to send a PM
PM Sent Jeff! AM
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car Last edited by andrew15; 04-21-2006 at 09:52 AM.. |
Stranger on the Internet
This is the result of my search for ARP rod bolts. I am at this moment installing the rods on the crank of my 3.0 SC. The ARP paper says stretch 0.0115-0.012". I have only a micrometer ( I have dial indicators, but am not interested in reinventing the wheel here). After three (3) go arounds as per ARP at 45 ft-lb, with the lube, the measured stretch in each of the two bolts I just did is only 0.008". I did measure them after the second go round, and the length of the bolt had increased by 0.005" from the non tensioned out-of-the-box length, so they are indeed stretching.
Tried calling ARP, but they're gone for the day. Next best thing is to ask you guys (maybe better, actually). For reference, I just last week did my 2.7 using Raceware bolts, torqued per Raceware instructions. After torquing them, I found the Raceware bolts to be of the prescribed length according to the micrometer. So, I am a bit puzzled by the results of this ARP tightening sequence. I am open to suggestions. Edit: It just occurred to me that the rods have been resized, and quite possibly were resized with the ARP bolts installed. So, it is possible that the bolts may have had a few thousandths stretch before I ever go to this point. Thanks! Pat
Patrick E. Keefe 78 SC Last edited by patkeefe; 07-12-2006 at 05:55 PM.. |
You talkin' to me?
ARP says you can re-use them multiple times.
1. Beg, borrow, or steal an actual stretch gauge. 2. If assembling on the bench, just use the gauge. 3. If assembling in the case, use torque-angle method: 3.a. Put rod in soft-jaw vise and torque both nuts to 5 foot pounds. 3.b. Use a thread marker, liquid paper, to mark the nut/bolt 3.c. Turn bolt until proper stretch level achieved. 3.d. Measure angle and then use 5 foot pounds plus that angle when installing on crank. This comes out so consistently it's almost always spot on. The reason is because at 5 foot pounds, the differences in friction coefficients have barely begun to come into play - it's just snug. When you look at how quickly the required torque to keep turning ramps up with each successive degree of turn, it's easy to understand why this can result in widely-varying torques for the proper stretch when you look at the entire set of 12 nut/bolt/combinations. The ARP site USED to say 3 times on/off with torque. NOW it says 5 times on/off. Hmmm, wonder why? Because while this method may be "good enough" in most cases it's obviously flawed. The whole idea of on/off is to burnish the nut/rod surfaces to try to get those friction coefficients more consistent. Torque-angle method gets around that by not letting the coefficents come into play in the first place. This is precisely why Porsche changed the head stud nut procedure to this method on the 3.6 at some point. Not sure what other engines they specify it for now - but engineering-wise it makes a heck of a lot more sense.
-Chance ------------------------------------------- '90 C2 Cab - Temporarily out of service Last edited by chancecasey; 07-13-2006 at 10:00 AM.. |
Chance
Thanks very much for the response. The methodology you describe makes excellent sense. However, in my case, there is pretty much no possibility that I will have a stretch gauge at my disposal. I did speak to the ARP tech support people today, and discussed the metallurgy of the bolts (an 86xx alloy, which I recall as being a wartime-developed alloy substitute for the 4130/4340 series chrome molybdenum steels), what it takes to exceed the yield and get the bolts into the plastic range, and the realistic differences between stretch method and torque method. Evidently ARP has suggested five torquing of the nut/bolt to allow the lubricant which they supplied to pretty much equalize the frictional components of the torque process, exactly as you describe. What I have arrived at with four successive torquing of the bolts is a very consistent stretch of 0.009" per bolt , measured with a micrometer. Intuitively, I would think that another 4 ft-lb or so would put me at just about the prescribed stretch. If I leave them alone as they are, I figure I'm losing a very small fraction of the clamping power of the nut/bolt assembly. If I try to honk them down a bit more, I risk getting into the plastic range (permanent deformation). With an engine which will rarely see 7000 RPM, I will leave them as is for now. Knowing a bit regarding the alloy they are made from, I feel better about them not letting loose on a straightaway somewhere. Of course, this becomes academic if a stretch gauge falls into my lap over the weekend. Far cry from the days of putting Chevy head bolts in with the farmer method..."tighten them until they squeak, and then go another 1/2 turn". Pat
Patrick E. Keefe 78 SC |
My guage has been all over Canada now, I think it wants a holiday the USA, so if anybody still needs to use one, drop me and email and I can get it sent out to you once I get a deposit!
Cheers
You talkin' to me?
This method should apply to all ARP bolts assuming:
1. thread pitch is the same as for the 3.6 2. desired stretch is .012" Make sure rod bolts are fully seated in the rod cap - you can do this on the bench by assembling rod and cranking down a bit on the nuts. Once you're in the case, torque each nut to 5 foot pounds. Turn each another 135 degrees. Results in .012" stretch. FYI P.S. - Anyone who is able - please verify this on the bench - then this should become standard procedure for in-case rod assembly.
-Chance ------------------------------------------- '90 C2 Cab - Temporarily out of service Last edited by chancecasey; 07-14-2006 at 02:54 PM.. |
Is 5 foot pounds enough to reliably seat the bolt and squeeze the two halves? Or would a first pass at higher, and then redoing it be better?
-Eric 90 C2 |
You talkin' to me?
Good question - it's kind of a trade-off between having enough snugness vs. getting into too much friction. Just lube up your bolts and 5 should be enough. Also, and this is important, make sure your bolts have bottomed out in the rod caps first - that definitely takes more grunt to get those seated. I'll update my previous post to reflect that...
-Chance ------------------------------------------- '90 C2 Cab - Temporarily out of service |
I just had a nice long discussion with the engineering staff at ARP. My concern is having insufficient tension on the rod bolts...this has been obviously gnawing at me for a few days now. Being a former machinist and mechanical engineer, I do not feel quite right about the 0.008 stretch instead of 0.0117 prescribed by ARP. Without going into too much detail, I have considered at what point will the reciprocating load on the rod overcome the tension in the bolt, and start the rod cap to wiggling around on the rod? If I take a chance and try to guess how much more I can torque these bolts without a gauge, I could quite easily get into the plastic range of the bolt, and at $35 bucks a bolt, I can't afford too many of those mistakes. I don't really need to blow up this engine due to my own negligence or stupidity.
So, I am heeding the advice of this thread, taking the guesswork out of the picture, and procuring a stretch gauge. And, I'll probably take the 2.7 case apart (that I just put together) and redo those rod bolts also. Thanks also to ARP for taking the time to review this stuff with me. Pat
You talkin' to me?
Wise decision - there are so many things you can mess up with these things as a weekend warrior - anything you do "above and beyond" is going to make you feel MUCH better afterwards. Otherwise these things will gnaw away at you later because you're just not 100% sure it's right.
i have torque my new rod bolts 35ftlbs 3 times in the case
should i torque them more? i read here you say better more than less torque |
I just had my case opened. The ARP bolts went back to the unsprung length when I took it apart (I had written down the measurements). I put them together again a week or so ago, with a stretch gauge, and rechecked the length. I basically ended up at 0.011" stretch.
spjuvern, you really need to either use a stretch gauge, or a micrometer to do this correctly. If you under stretch them, you are leaving a lot of clamping force on the table. If you overstretch them, they are junk. I think if you folllow ARP's instructions EXPLICITLY, you should be OK.
Certified Pre-Owned
I just went through this yesterday and my opinion is that the 35 ft.lbs. tighten and loosen 3 times is a bunch of b.s.. (part # ARP 6005). If you do that I'm measuring about .0085-.009" of stretch when you hit 35 ft. lbs on the final torque. I found it was hitting upwards of 45-50 ft. lbs. on my wrench to hit the .0115" value and get into the correct range. So my opinion is that the 35 lbs is a bit low and it sounds like that's the consensus. What makes a lot more sense to me as someone else stated is to go to X torque and then add some Y degree of rotation much like the Porsche procedure. Its sort of annoying to buy $225 worth of bolts and then find out you need to chase down the special gauge. Oh well...
Keep in mind too that not everyone's torque wrench in calibrated exactly the same, but I think 10-15 ft. lbs more is a sizeable jump over 35. I also think while its good to be as thorough as patkeefe is, you can drive yourself insane worrying about rod bolts; after all you bought the ARPs anyway to get a stronger bolt than factory. I believe if you get close to the stretch range you're in good shape. I would probably worry a bit more if I was entering LeMans with it...
'84 Carrera Coupe Last edited by BGCarrera32; 03-08-2009 at 06:39 PM.. |
Certified Pre-Owned
) and also why I think the 35 ft lbs. is a bit too low.
'84 Carrera Coupe |
Stress Strain
The ARP rod bolts are similar to the curve in the following link:
http://darkwing.uoregon.edu/~struct/courseware/461/461_lectures/461_lecture24/461_lecture24.html Once you get past the "top of the straight line hill", you are in the plastic range, which means permanant deformation. An ARP rod bolt is essentially junked if you pass this spot, and further torquing (stretching) will result in "necking" of the fastener. The limit is, as ARP says, around 0.0115" stretch, which does not correlate to torque for many reasons (there is a lot of good info here on ths board regarding this). Engines cost, what, $7000 to build? Buy a micrometer for $50 and check the stretch. Very cheap insurance. ![]() Pat
I'm here to cause trouble
We just did some ARP bolts a little while ago... from my failing memory, I recall that to get to the proper stretch we were 50-55 foot pounds on my uncalibrated wrench ... at 35 foot pounds, I think we were at about 60% of the spec stretch.
JB |
Certified Pre-Owned
'84 Carrera Coupe |
