JE Shelf Piston Size
Are all JE off-the-shelf piston sizes xx.00mm? What I mean is if I buy a set of 98mm, will they measure out to 98.00mm?
With all the Mahle size groups being slightly smaller (e.g. 97.97mm), is it just a matter of finding good condition Nikasil cylinders and having them honed to the right P/C clearance? Would I have to worry about honing through the Nikasil coating, or is it thick enough that a few tenths of a mm won't be an issue?
Tom
1978 911sc Targa (Sold )
2005 BMW X5 3.0i
2000 BMW 528iT (5 spd, sport)
2000 BMW 323Ci conv. (4 sale)
1987 Corvette Callaway Twin-Turbo Conv
Old 04-20-2006, 09:53 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Usually after getting the pistons a machiner will match the bore to your piston's exact size because the clearance between the piston and the wall is really small.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 04-20-2006, 10:38 AM
I think I understand that part. Let me rephrase my question(s) a little bit - are the shelf JE pistons always bigger than or equal to the biggest size group of equivalent Mahle pistons? (i.e. you can only machine a bore bigger, not smaller to fit) And, if you're machining the bore bigger to match the JE piston and get the right clearance, does one need to worry about machining/honing all the way through the Nikasil plating?
2005 BMW X5 3.0i
Old 04-20-2006, 10:53 AM
MBruns for President
JeremyD's Avatar
Yes and measure measure and measure.
For your piece of mind - the JE pistons I received were VERY accurate. less than .5 grams difference - bores size out to 3 decimal places
The cylinders in the other hand were not, even thouse were straight back from the plater. Measure. AND used cylidners that are rebored also have the opportunity to have some taper and some out of roundness.
Old 04-21-2006, 12:14 PM
