JE Shelf Piston Size
Are all JE off-the-shelf piston sizes xx.00mm? What I mean is if I buy a set of 98mm, will they measure out to 98.00mm?
With all the Mahle size groups being slightly smaller (e.g. 97.97mm), is it just a matter of finding good condition Nikasil cylinders and having them honed to the right P/C clearance? Would I have to worry about honing through the Nikasil coating, or is it thick enough that a few tenths of a mm won't be an issue? Tom
1978 911sc Targa (Sold )2005 BMW X5 3.0i 2000 BMW 528iT (5 spd, sport) 2000 BMW 323Ci conv. (4 sale) 1987 Corvette Callaway Twin-Turbo Conv |
Usually after getting the pistons a machiner will match the bore to your piston's exact size because the clearance between the piston and the wall is really small.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
I think I understand that part. Let me rephrase my question(s) a little bit - are the shelf JE pistons always bigger than or equal to the biggest size group of equivalent Mahle pistons? (i.e. you can only machine a bore bigger, not smaller to fit) And, if you're machining the bore bigger to match the JE piston and get the right clearance, does one need to worry about machining/honing all the way through the Nikasil plating?
MBruns for President
Yes and measure measure and measure.
For your piece of mind - the JE pistons I received were VERY accurate. less than .5 grams difference - bores size out to 3 decimal places The cylinders in the other hand were not, even thouse were straight back from the plater. Measure. AND used cylidners that are rebored also have the opportunity to have some taper and some out of roundness.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
