shbop's Avatar
2.0 perimeter nuts?
Early 2.0 case. Any problem changing the perimeter nuts to nylocks? Any torque difference? Thank you!
Jon
Old 04-21-2006, 10:21 PM
Try not, Do or Do not
Henry Schmidt's Avatar
No need for nylocks. On Porsche case they were only used in conjunction with aluminum washers.
Not a good idea with aluminum case.
You will also find the studs are too short for a functioning nylock application.
Clean the case well, use ThreeBond 1104, standard nuts and spring washers and you'll be fine.
cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-22-2006, 06:23 PM
