Ho Hum 74's Avatar
Mounting thru body front sway bar - help needed
Folks,
Trying to mount this through body sway bar on a 86 carrera. I can see where the hole needs to be drilled in the wheel well but I'm stumped as to how you get the backing plates on the inside wheel well without removing the gas tank. Any ideas??
Wayne's teh article says that 911s don't need to remove the gas tank....it's not obvious to me.
Tristan
Old 04-22-2006, 12:42 PM
J Smith's Avatar
Here's a good thread with some helpful tips.
Josh
'87 911 Carrera 3.2 Coupe
Old 04-22-2006, 12:52 PM
Ho Hum 74's Avatar
Thanks Josh. That helps me a lot. Appreciate it.
Old 04-22-2006, 12:57 PM
Ho Hum 74's Avatar
front is in....perfect.
Old 04-22-2006, 04:46 PM
