Cam Questions for 3.2
The valve guides need to be replaced in my 1987 Carrera. The car has 42,000 miles.
While the engine is out and the heads are off I want to do the following: New studs New rod bolts Stiffer springs Replace cams with something better. The engine has the following mods. Back dated exhaust using SSIs Cat removed Dynamax exhaust Steve Wong Chip What type of cams do I need? The car is a daily driver,(I have owned it for the last 2.5 years and have put 24, 000 miles on it.) I would like more power. How much could I expect?
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
Still Doin Time
You'll be very limited in cam choices with the stock motronic dome pistons. I believe the '964' grind is about the limit. It is a modest increase in lift and duration. You would see some gain in HP/TQ. You'll still have to check valve to piston contact.
Anything more aggressive will require different pistons /dome configuration. At this point (as someone here said well) it is a very slippery slope $$ on upgrades.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
3.4 Bigger is better
Si Banker,
Give John a call at www.drcamshafts.com he will guide you on what the best grind would be for what you want to achieve. There are many threads about this also. Steve Wong would be able to tell you the pros and cons of different configurations. I am rebuilding my engine and have gone to 3.4 P&C's with John's DC22 cam with his performance valve springs on my 88 Carrera. I have the euro pre muff and a Steve W chip on mine. Sending the chip into Steve to get it programmed for the mods I have done. Can't tell you how it will be as I'm am still rebuilding. I wanted to go as aggressive as I could. It is a street driver and some DE's, auto cross.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport Last edited by 88-diamondblue; 05-02-2006 at 08:35 PM.. |
Results
What could I expect in HP gains by going to the new cams? Also what could I expect if I went the 3.4 route in HP gains.
What would the 3.4 do to drive-ability and would there be a increase in oil temp> I have to deal with the Texas summers.
MBruns for President
about 10 degrees higher - with the 3.4 - actually the 3.4 acts JUST like the 3.2 until you get into the higher RPM's =
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
oh - I have the motronic 3.4 P & C's - and 993 SS cams. Had to relief the piston tops .5mm on the exhaust side - but she runs like a scalded cat...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 Last edited by JeremyD; 05-03-2006 at 11:14 AM.. |
I am hoping for a 30 to 40 hp increase over stock. Worked with Henry and Camgrinder on the configuration and came up with those HP increase expectations. I didn't do a dyno before so I will never know for sure how much but I am going to dyno to fine tune the chip. Supertech has a very affordable 3.4 upgrade or getting your cylinders bored and replated, then use JE pistons. If I only had more money
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
