Should I do a rebuild?
Car has 200,000 on it. Should I rebuild now or wait? What are the advantages of rebuilding? Should I do it myself or have it done? What costs am I looking at if done myself or done by a pro?
Old 05-04-2006, 07:09 PM
id911T's Avatar
What kind of car? Does it have any problems?
Stephen
GruppeB #906
1970 911T
Old 05-04-2006, 08:32 PM
If you are an experienced and knowlegable DIY, you can rebuild successfully using the Wayne book and info. in this BBS. The key word is CAN, there are, IMHO, many places to mess up. Also when you DIY, you don't have a warranty. You can find other tips on this BBS if you decide to DIY. Good luck either way.
-h
Sold: 1989 3.2 coupe, 112k miles
Old 05-16-2006, 06:19 AM
m_wuebben's Avatar
Along the same lines, if one does a rebuild, is it ever advisable to just do the top end, or is it, "you have the engine out anyway, split the case and do it all?" Cheers, Mike
1981 911 SC Black / Black & Tan sunroof coupe.
Run like the wind...straining the limits of machine and man... (Peart)
Old 05-16-2006, 09:08 AM
Main reasons for rebuilds are related to worn valve guides and piston rings (2 main wear areas of the engine). This requires top-end only.
My mechanic says that prior to splitting the case, he removes the rods to assess the condition of the big-end bearings.
Healthy big-end bearings practically always come with healthy main (crankshaft) bearings as well.
That's part of his judgement whether or not to split the case.
If oil pressure is low, this is a general sign of worn bearings that would make me decide to split the case and renew all bearings regardless.
Old 05-16-2006, 01:38 PM
