Try not, Do or Do not
Henry Schmidt's Avatar
FAA-certified Airframe and Powerplant ?
I'm wondering if an A&P ceterficate is required for engines in this application?
You can make them look good, but what we really want is flight.
It might sing on the dyno but can it fly?
photo by Mike Hally
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-05-2006, 09:39 AM
MBEngineering's Avatar
good result for the first time out in the car and your engine, 1st in class C4 car 24 Steven Smith/John Nichols (SUPERTEC engine, MBEngineering gearbox), 2nd in class C4 car 20 Jimmy McRAE/Cambell Roy, 41 sec behind, both 911 3.0l cars, full results at www.welshinternationalrally.com.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 05-05-2006, 11:34 AM
Truly great stuff, Henry.
250 ft-lbs between 2,600 and 6,800
228 BHP at the wheels..
What a lovely drive...
Kind regards
Old 05-07-2006, 03:05 PM
Send a message via AIM to fintstone
Pretty impressive Henry! Beautiful engines too! Is that photo in your new shop? Bernard?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-09-2006, 10:38 PM
HI may be we could have a fly past, if we get more on the air????
regards mike
Old 05-12-2006, 10:41 AM
Originally posted by fintstone
..... Is that photo in your new shop? Bernard?
Hi Stoney
Yes on both counts. It's tiny here but we like it.
How's that sweet little car of yours running?
Henry Schmidt
Ph: 760-728-3062
Old 05-12-2006, 11:01 AM
abit off center
cgarr's Avatar
Henry, The only way you will get your A&P ceterficate is if you lower your standards,,
Old 05-12-2006, 12:29 PM
BReyes's Avatar
No but I once saw a 911 with a license plate loflyer. Now i have a new visual.
Bernard
Old 05-12-2006, 12:35 PM
Originally posted by Henry Schmidt
Hi Stoney
It runs great..thanks to you. I am finally getting the A/C installed as we speak....by another Pelican who is very skilled/experienced in that area....much better than me. I have been gathering up the parts for a long time but gave up on finding the time between work and my AF Reserve duty taking up all my time. It should be state of the art to match the engine....and I want to drive it year round.
Old 05-12-2006, 07:16 PM
HI do we have to get a set No of Porsche cars in the air to qualify for a FAA cert.
regards mike
Old 05-20-2006, 08:00 AM
Hi Mike
Can you tell me anything about that roof mounted air scoop?
Is it available to the public? How has it? How much?
Henry Schmidt
Ph: 760-728-3062
Old 05-20-2006, 11:56 AM
HI henry the car it is on is from francis tuthills workshop (one of my old boses) i some times helpout with the cars, he is at www.francistuthill.co.uk ask for paul and say i put you in tuch as i do not know if thay sell them on/out. i could in enquire for you if you like, to get one and send it over??, i have some paperwork for you and was going to send it next week any way.
regards mike
Regards mike
Old 05-20-2006, 12:47 PM
Cool Thanks
Henry Schmidt
Ph: 760-728-3062
Old 05-20-2006, 12:54 PM
HI HENRY could have found a other supplier for the roof scoop, will let you know when i have contacted them. paper work is on it's way
regards mike
Regards mike
Old 05-24-2006, 08:49 AM
Did you guys source that roof scoop? I came across a supplier recently.
Old 06-03-2006, 10:58 PM
Hi Stony
Not yet, PM me with info if you have some.
Los Vegas? Did you move?
Henry Schmidt
Ph: 760-728-3062
Old 06-04-2006, 06:15 AM
Sent you a PM. Yep, I am in Vegas now...although my car and most of my 911 and most of my stuff are still in Albuquerque (I have been to busy to really move). We are almost neighbors. I will have to try to get by to check out your new digs.
Old 06-04-2006, 09:39 PM
HI Henry i see your engine had a outright win at the weekend in the red car, did you sort any air scoops in the USA as i have 2 contacts over hear now, did the paper work turn up ok???
regards mike
Regards mike
Old 06-07-2006, 09:17 AM
}{arlequin's Avatar
what are the little lights for on the yellow car? (above h4's?)
dave
1973,5
Old 06-07-2006, 09:19 AM
HI high wattage dust lights , the car is on the africa rally last year and it was a bit dry and rocky, as in the photo,
regards mike
Old 06-07-2006, 09:38 AM
