What kind of compression #s should one see with a 3.4 liter motor? Pistons are Mahle Sport 98mm. Deck height is .045". Cylinder heads are stock with the exception of the bevel cut for the 98mm pistons.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
depends on your cam profile and static compression ratio to some degree....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jeff, What are your #s? Are you running the Mahles or JEs? I just want a base line is all. My cams are stock 3.2. Cam timing (if it matters) 1.22 L and 1.24 R
Mine is not together yet. I have measured the domes, checked the deck height and I am cc-ing my heads tonight, hoping for 10.5 or so. I may have mis understood your question. DId you mead #'s from a compression test or did you mean static compression?
My motor has JE pistons. Cheers
Mahle sports should come out almost exactly as stated. 9.8:1 or 10.5:1 epending on the Mahle 98 you used, RS or Max Moritz.
Hmmm, not sure but I would think you should see 180+ on that motor.
Cheers
Mahle has a bit of a rep for overstating compression ratios..... I know Ralph had a heck of a time getting any thing even remotely close to the stated CR on his set of p/c
Cheers
Check with EBS and the they will tell you the Mahle's do come as stated. My 3.4's did once the early heads were sorted out. I staretd with a 10.8 instead of the 9.8 because of the smaller heads used from a 3L.
We must be talking about different styles of pistons. The Mahle RSR style high domed ones are way overstated..... As are most factory mahle pistons.... At least that is what people have been saying here that have measured them. Ralph and Chris come to mind. That said, I have only measured the JE's and they were bang on 10.5
Cheers
MBruns for President
3.5's are known for being overstated = the 3.4's are typically pretty on. My 3.4 with JE's came in at 9.78 to one - my Mahle Sports came right at 9.74 when some relief was cut for the exhaust valves.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
