syncroid's Avatar
Question Compression #s for a 3.4
What kind of compression #s should one see with a 3.4 liter motor? Pistons are Mahle Sport 98mm. Deck height is .045". Cylinder heads are stock with the exception of the bevel cut for the 98mm pistons.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 05-11-2006, 05:29 PM
Jeff Alton's Avatar
depends on your cam profile and static compression ratio to some degree....
Cheers
www.turn3autosport.com
Old 05-11-2006, 06:21 PM
syncroid's Avatar
Jeff, What are your #s? Are you running the Mahles or JEs? I just want a base line is all. My cams are stock 3.2. Cam timing (if it matters) 1.22 L and 1.24 R
Dan
Old 05-11-2006, 07:53 PM
Jeff Alton's Avatar
Mine is not together yet. I have measured the domes, checked the deck height and I am cc-ing my heads tonight, hoping for 10.5 or so. I may have mis understood your question. DId you mead #'s from a compression test or did you mean static compression?
My motor has JE pistons.
Cheers
Old 05-11-2006, 07:57 PM
syncroid's Avatar
From an actual compression test. (after the motor has been run...say 1000 miles)
Dan
Old 05-11-2006, 09:51 PM
rdane's Avatar
Mahle sports should come out almost exactly as stated. 9.8:1 or 10.5:1 epending on the Mahle 98 you used, RS or Max Moritz.
Jeff Alton's Avatar
Hmmm, not sure but I would think you should see 180+ on that motor.
Cheers
Old 05-11-2006, 10:22 PM
Jeff Alton's Avatar
Mahle has a bit of a rep for overstating compression ratios..... I know Ralph had a heck of a time getting any thing even remotely close to the stated CR on his set of p/c
Cheers
Old 05-11-2006, 10:23 PM
rdane's Avatar
Check with EBS and the they will tell you the Mahle's do come as stated. My 3.4's did once the early heads were sorted out. I staretd with a 10.8 instead of the 9.8 because of the smaller heads used from a 3L.
Old 05-12-2006, 10:00 AM
Jeff Alton's Avatar
We must be talking about different styles of pistons. The Mahle RSR style high domed ones are way overstated..... As are most factory mahle pistons.... At least that is what people have been saying here that have measured them. Ralph and Chris come to mind. That said, I have only measured the JE's and they were bang on 10.5
Cheers
Old 05-12-2006, 11:49 AM
MBruns for President
JeremyD's Avatar
3.5's are known for being overstated = the 3.4's are typically pretty on. My 3.4 with JE's came in at 9.78 to one - my Mahle Sports came right at 9.74 when some relief was cut for the exhaust valves.
Old 05-13-2006, 07:42 PM
