Oil lines for 69S from update kit to short?
I am putting an chain tensioner update kit on my 69S while I have the engine out but the line for the right side seems to be too short. Is there an extension or a longer line available for a 69?
don |
3 restos WIP = psycho
Don, here's the best pic I could get out of my car without tearing things apart:
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Try not, Do or Do not
There are two different oil lines for the right side when you use Carrera tensioners.
The only number I could find for the long one is: 930-107-348-XX. If you can't find one you can replace the hose on the short line with a longer peice. This requires a crimper and the correct farrels. We have both in stock. We also have about 8 of the longer hoses in stock.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Here is a picture of my problem.......................
up-fixing der car(ma)
Where did you purchase these from?
Scott Kinder kindersport @ gmail.com Last edited by YTNUKLR; 04-28-2006 at 03:17 PM.. |
Jerry St. Germaine at EuroEast
I'd ask him for the right pipe.
Don, If Jerry doesn't have it or can't provide it to you, you can order the longer right connector, an "oil line adaptor", from the Pelican competitor in LA, part #901566 @ $17.95. I had to do this as the kit for my 70 S also only had the shorter right connector.
Phil Y, Kapolei, HI 04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago |
