sealing the engine
Hello
is there any problem to apply the sealant on the left case instead of the right one ? Philippe |
I just did mine and it seems it would be much easier to do the right side, as it is attached to the stand and does not have to be handled after 574 is applied. Use an acid brush, it makes it much easier(in the plumbing section for the flux)
Donnie Currently Porsche-less.....
You can put it on either side. I find it easier to put it on the side without all the studs sticking out. Be careful to not let any get sealant get into the oil passage areas.
-Andy
72 Carrera RS replica, Spec 911 racer |
ok Andy
seems to be easier without the studs for me too... thanks |
