Web-Cam 104/102 timing lift spec? Anyone?
I think I calculated my web-cam 104/102 grind timing lift wrong for my 2.4L. Does anyone know the amout of lift if should have when timing it as specified in Waynes book? In other words, what should the dial indicator read when the valve spring top is lifted?
If an S cam is 5.2mm or 0.20inch what is the web cam?
I like them I drive them |
Set that one at 4.2-4.6mm.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks Steve!!!!
Thats with the valve set at .004 and not at 0, correct?
For future refrence thats Thats with .004 lash and trust me it makes a diffrence if you get it wrong.
get a flippin' metric dial gauge this time!
