Me like track days
Craig 930 RS's Avatar
Question 98mm P&Cs for the 930........Mahle the only way to go?
$4,000 for Mahle 98mm P&Cs........is there another way?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-28-2006, 01:03 PM
Alan.UK's Avatar
Edit (Just noticed yours was for a 930)
I went for 98 J&Es with new "Perfect Bore" barrels. 10.5 CR on a single spark system. 46 carbs and S cams. Puts out 260bhp. Built around a 78SC motor.
I can find out what I paid, I think I have tried to forget as it wasn't cheap.
Alan.UK
Old 05-28-2006, 01:54 PM
Send a message via Yahoo to Lukesportsman
I like the above mentioned option very well and can be secured well under $4k.
Check also with Henry as he has brought out some options.
PELICAN sells Nickies and in my opinion, this is the "best" that technology will buy you, though it won't save you money on the front side.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 05-28-2006, 09:07 PM
I have nickies on my high hp engine. They are in a different league than the mahle stuff
Eric Hood
Old 05-29-2006, 03:21 PM
resident samsquamch
sand_man's Avatar
I've got Henry's (Supertec) 98MM on mine...stay tuned, I just finished wiring up the twin plug ignition and should be good to start the engine tomorrow.
-jeff
Old 05-29-2006, 04:58 PM
Wo ist die Rennstrecke?
DonE's Avatar
You need to consider the cylinders made by JB Racing. Steel sleeves, with AL fins. They all but eliminate blow by on forced induction motors, allow you to use any rings (like molly), work extremely well with JE pistons (no taper like Mahle cylinders), can be made to precisely fit any piston/ring combination and are race proven. Oh yah, they are reasonably priced (unlike Mahles right now).
www.jbracing.com
Old 05-29-2006, 06:11 PM
Super Moderator
cstreit's Avatar
I've got Nickies in my race engine too. They are works of art, highly recommended.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-30-2006, 07:42 AM
Me like track days
Can someone expalain a nickie vs. a Mahle?
Old 05-30-2006, 08:18 AM
The mahle (and every other nikasil cylinder) is a cast piece. The Nickies are a billet cylinder made from our proprietary extruded aluminum alloy into which the fins are cut. The biggest difference between our aluminum and other is the strength (+66%) and thermal conductivity (+100%). The drawback is the price, as we have LOTS of machining time and scrap (each cylinder starts off as a 17# slug then becomes a 1-2lb cylinder). The other difference are the expansion rates (our alloy has less silicon), so it expands more, allowing for tighter ring gaps while reducing ring wear and a better fit (tigher clearances) with JE Pistons.
That said, I'd love to sell them to every customer that calls or walks in the door, but in some cases they are not necessary, unless you want something that will outlive your Porsche and your engine rebuild :-)
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 05-30-2006, 08:45 AM
resident samsquamch
sand_man's Avatar
I really wanted to do either the Nickies or the JBs, but I honesly just ran out of $$$$! For my purposes (a daily driven 930 with a .8 BAR Tial wastegate) that the Supertec cylinders with JE pistons will be fine. I figured that at least they're new (not replated), and have the cooling fins on top, so that's at least better than what I had...
-jeff
Old 05-30-2006, 12:04 PM
Agreed :-) Those half-finned cylinders are horrible.
Charles Navarro
Old 05-30-2006, 12:54 PM
MBruns for President
JeremyD's Avatar
Cost no object - go with the nickies - next notch down (but plenty of high HP engined under their best) JBracing. With a turbo, especially a tracked turbo, that is what I would do.
Old 05-30-2006, 07:00 PM
Me like track days
What objective evidence is there that the 'nickies' are better for a track situation than the Mahles? Not a challenge, just a question.
Old 05-30-2006, 07:04 PM
JeremyD's Avatar
http://www.lnengineering.com/racing.html
Old 05-30-2006, 07:31 PM
I have just bought Henry/Supertec's P&C as well. Will be at least a few weeks before I have the car back together to know any results.
But, if service is anything - the first shipment I received had a broken fin. Could be UPS or anything. No quesions asked - Henry said to return it & he'll send a replacement set & deal with the damage on his end. Now, that's service in my mind!
What swung me over was price & as Sandman said, its better than the replated ones. I can't justified new Mahle/Nickies yet.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 05-30-2006, 07:45 PM
Jeff Alton's Avatar
Craig, were the ones in your motor new when it was rebuilt? Not a glowing recommendation for Mahle.......
Cheers
www.turn3autosport.com
Old 05-30-2006, 11:29 PM
resident samsquamch
sand_man's Avatar
When I set out on this journey, I was really stressing over this particular area. No matter how I crunched the numbers, I just couldn't do it. Don't laugh, there are a number of cars that I could purchase - all capable of making smile in one way or another - for what you can spend on f_cking Ps&Cs!!! Then out of no where, Henry sent me an email and offered another option! I didn't look back...
-jeff
Old 05-31-2006, 07:14 AM
magic930's Avatar
Craig,
I have 4500 miles on my 3.4L 98mm "nickies" with JE pistons, ARP head studs, no issues so far. Talk to Charles at LN Engineering. I think you can also buy these thru Pelican.
Old 05-31-2006, 06:41 PM
