No problem david.
Have you any ball park figure on time? I'm in the 3-6 month time frame. If that falls in your window, please keep me in mind. tadd
1967 912 with centerlocks… 10 years and still in pieces! |
Hello, Tadd.
I am planning to get these available in 8 weeks...barring unforeseen problems.. So they and Henry's barrels should be available Real Sonn Now.. Kind regards David |
BTW, we've offered this same cylinder since 2004, in both the 2.2 style (w/o sealing groove using 3.2 carrera taper/ or dead nuts flat) and the 2.0 style sealing surfaces, but I'm sure Henry's offering as cast will be more affordable :-) Pelican should have them in their catalog somewhere...
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Try not, Do or Do not
We're done with the first round of on track testing and they are in stock and ready for delivery . With any luck you should see them on the Pelican website.
Let the fun begin.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Hi Henry
I have 80.94 Mahle piston, what is the diameter of your barrels? Thanks |
There are variations in manufacturing.
