930 Deck Height?
I just measured the deck on my 76 930. With the .25 mm base gasket, I get a deck height of .035in or .889 mm. Will this be enough clearance considering I will be using 964 cams that have higher lift than the 930 cams?
Update: I just checked again and and the measurments on all come out to .043-.044 which is a bit more than 1mm so I guess this will be enough.
I was taking the measurement in the wrong place before at 12oclock rather than at 3 or 9oclock above the pin.
76 Euro 930 restoration
Website
Old 06-16-2006, 11:43 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The numbers you report should be adequate for 964 cams.
It never hurts to add valve pockets.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-17-2006, 11:36 AM
David's Avatar
To be safe, I'd bolt on a head with a couple of pieces of solder on each side of the piston and turn the engine over. The thickness of the squished solder will be a better measure of you're squish band.
Old 06-19-2006, 08:51 AM
