johncmng's Avatar
Porsche Crest Removing swaybar???
I just started disconnecting wires and hoses for an engine drop. Then I proceeded on the bottom of the car and I notice that the swaybar may be in the way of the transmission. Do I have to remove the sway bar to drop the engine?
Old 06-19-2006, 08:27 AM
I had to remove it when dropping my engine & tranny together.
If you drop the engine alone, I think you can leave it in.
Maxx
86 Ruf'd and rebuilt (sold)
Old 06-19-2006, 09:20 AM
remove U clamps and loosen the pivot bolts....swing out of the way....you can leave the sway bar attached....
not sure what car you have....that's what I did on my 89 3.2
Old 06-19-2006, 03:35 PM
spray all the nuts and bolts with PB blaster and let them soak overnight. Remove the lower bolts (single bolt closest to the ground) first. If you remove the bolts (where the rubber bushings are) when rotate your breaker bar the entire sway bar will pivot towards the ground (the nuts are on very tight). If you happen to do it in reverse (like I did), you can put a piece of 2x4 under the sway bar to keep it from rotating towards the ground. You'll need a breaker bar...hope this makes sense.
86' 911 Carerra
Old 06-19-2006, 07:22 PM
Super Moderator
cstreit's Avatar
Just disconnect the chassis pivot and swing it towards the front of the car... THe tranny will clear it.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-19-2006, 09:39 PM
Chris is correct...I just did the extra work to get it completely out of the way... this saves using a big breaker bar and torquing with the weight on the tires which is a pain..big wrenches and no room
Sold: 1989 3.2 coupe, 112k miles
Old 06-23-2006, 06:00 AM
Less brakes, more gas!
euro911sc's Avatar
I just removed the whole bar... In the scheme of things its not a big deal. Then you can paint/powdercoat it while you are waiting for parts
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-23-2006, 12:28 PM
