Wil Wil is offline
3.0 SC Time-serts size question
I have decided to use Time-serts to fix my loose head stud problem. Does anyone know the correct size time-sert kit to use to get the full thread length? part number?
Old 06-22-2006, 04:07 AM
MBEngineering's Avatar
HI try this site www.wurth.co.uk then type in time-surt should give you the full list+spairs.
the insurt length is 20mm. if it is for the head studs you will have to mod' the resess tool to clear the cylinder base spigot
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 06-22-2006, 04:39 AM
3 restos WIP = psycho
kenikh's Avatar
Time Certs, from everything I can read, are old tech and inferior to Case Savers due to the fact that they are installed with an interference fit and can thus come loose. Why are you not using the Case Savers instead?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-22-2006, 08:56 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Locitite sleeve and bearing mount (green) will most likely cure a very slight wiggle.
A Timesert will work fine in an aluminum case.
CaseSavers are old technology. They just happen to work the best in a mag case. The reason they work better in mag case is that they come in many different size (10mm) and they have varying thread pitches on the od.
The CaseSaver is technology left over from the Type I bug days. They have been around since the late 60's.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-23-2006, 04:36 PM
