Try not, Do or Do not
Henry Schmidt's Avatar
74 Turbo Project
We finally completed the 74 Turbo project we've been working on.
What a sweet ride.
3.0 non intercooled, twin plug turbo.
Supertec twin plug distributor w/ BurnBros Marelli conversion
Taylor wires custom made
935 pistons
911 SC cams
SUPERTEC head studs
38 mm ports In and Ex
K27
B&B headers
1 MSD 6Al triggering two Blaster II coils.
On the test drive we made .1 bar of boost @ 1800 RPM climbing my hill.
Full boost of 1.0 bar @ 3400.
No dyno sheet yet but what fun.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-21-2005, 10:26 AM
Henry,
Very, very nice!
Eddie
'71 914/5
Old 09-21-2005, 10:42 AM
89turbocabmike's Avatar
Nice Henry, I love seeing that 12 plug dizzy tucked in there. I see one in my future
Old 09-24-2005, 05:15 PM
Licensed User
Shuie's Avatar
Nice!
Henry, would that fit under a stock flat deckild? 9 or 6 bolt crank?
Old 09-25-2005, 05:41 AM
This engine would fit nicely in a narrow bodied, no tail car.
Sleeper?
The engine was custom build using a 1980 911SC core. 9 bolt crank.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2005, 07:02 AM
Licensed User
Shuie's Avatar
Originally posted by Henry Schmidt
Sleeper?
Yep, thats what I was thinking. thanks for the quick response.
Old 09-25-2005, 07:24 AM
henry
firstly, nice work (as always)
secondly, was there a specific reason for not using an i/cooler (classing?)
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 09-26-2005, 12:23 AM
First, we know turbos perform better and safer with an intercooler. That said here are the reasons.
We were trying to make 350 hp not 400+
No need for a turbo tail. sleeper
Something different.
Cool looking.
Reduced turbo lag.
This engine under load starts making boost at 1800 rpm.
Try that with an intercooler.
And the main reason we chose not to use an intercooler was that I have built several of these in the past and they're just great fun to drive.
Henry Schmidt
Ph: 760-728-3062
Old 09-26-2005, 06:59 AM
iamchappy's Avatar
Henry I am having my 79 3.0 SC engine rebuilt, I fabricated and turbocharged it and am using it in my 914. I added an intercooler to it and was planning on boosting it to 11lbs. I am using the stock cis and a 7th cold start injector for enrichment.
I use a MSD BTM for ignition retard with the SC distributor. K27 turbo, Tial bov and wastegate.Everything has worked very well at 9lbs without the intercooler.
? What do you recommend for piston and cylinders and compression for my set up, and should I twin plug it.
This is a street car so boost would be as short bursts now and then 350 to 400hp will be plenty for my joy rides.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 09-26-2005, 10:02 AM
henry: thanks for the explanation - fun ride!
Cheers, Ryan
Old 09-26-2005, 03:34 PM
Just for *****s and giggles I wanted to see where my motor starts boosting.
I was in 4th gear at 1500 rpm and I booted it. At around 1800 rpm I saw positive pressure. That is my boost threshold.
I also noticed no difference when I installed a large intercooler. I think it is a wives tale that intercoolers increase lag. Kinda like the internet rumor that the G50 weighs 100 lbs more than a 915
If you think about it. The increased area in an intercooler is small and the turbo moves a TON of air. Hence no increased lag
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 09-26-2005, 05:21 PM
KobaltBlau's Avatar
Hi Henry, just found this. What compression ratio and cams did you use for this? thanks in advance.
Andy
Old 10-06-2005, 12:03 PM
iamchappy's Avatar
Henry, Please let us know when the twin plug distributors are available.
87 924S
Lexus SC400
Lexus LS400
Old 10-06-2005, 12:47 PM
7.5 to 1 with 911SC cams.
[QUOTE] Originally posted by iamchappy
The conversion distributers are available now. Look on Ebay
Henry Schmidt
Ph: 760-728-3062
Old 10-06-2005, 02:13 PM
iamchappy's Avatar
Henry, do you have any recommendations as to pistons and cylinders to fit on a 79 SC engine. I would like to run up to 11lbs of boost with an intercooler.
With all of the options out there right now I cant decide. What would you fit and would you increase the displacement.
87 924S
Lexus SC400
Lexus LS400
Old 10-06-2005, 02:22 PM
The 74 project used 935 pistons and 911 SC cylinders.
I'll check my stock if you would like.
We have also built a few engines using 3.3 turbo piston on a 3.0 crank. It requires some rod modification but it is a reasonably priced option to make your engine larger. These engines turn out to be something like the 935 IMSA 3.12 liter. Those silly things made over 700 horse with IMSA legal booth. 1.4 Bar?
Just checking but do you have an exhaust (header system) or intercooler yet?
I have a 914-6 turbo header and intercooler for sale. If you might be interested I'll post pictures.
Henry Schmidt
Ph: 760-728-3062
Old 10-06-2005, 02:35 PM
iamchappy's Avatar
I have everything under control as far as plumbling. I like the idea of replating my existing cylinders and fit them with the 935 pistons, please do let me know if you have any nice ones and PM me with a price.
87 924S
Lexus SC400
Lexus LS400
Old 10-06-2005, 02:47 PM
Is there any boost retard built into the distributor?
Matt B
'73 911E
Old 10-06-2005, 10:19 PM
The distributor has both mechanical and vacuum advance so when the boost comes on the vacuum goes away retarding the timing
Henry Schmidt
Ph: 760-728-3062
Old 10-06-2005, 10:42 PM
So at 0 bar and 1 bar the advance is the same?
Matt B
'73 911E
Old 10-07-2005, 08:46 AM
