Henry,
I have a 74 2.7 MFI, what modifications to the stacks did you have to make to use the PMO air filters? Does anyone sell a filter kit for MFI that eliminates the stock air box? Where did you route the crankcase vent?
Great engine, if I only had the money...
'74 Euro Carrera 2.7 MFI
Old 07-12-2006, 09:37 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I don't know of any bolt on air cleaner kits.
I order to fit the PMO filters on the MFI system you must change the mounting hole and remove the altitude compensator.
The crank vents to the oil tank as usual. The difference is that the oil tank now vent to a small oil reservoir ( 91 turbo) with a drain to the engine breather so that you never have to empty it.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-12-2006, 11:31 AM
Originally posted by Henry Schmidt
IMO: Short stroke, twin plug, MFI, 3.2.
Fast, powerful, reliable and period correct.
So, it's better than 2.8SS now?
Old 07-12-2006, 02:58 PM
3 restos WIP = psycho
kenikh's Avatar
Not better; different! No 3.2SS is going to spin to 8600 RPM!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-12-2006, 03:05 PM
Very good ! I could not have stated it better.
I would add that what's best for one enthusiast may not be best for another.
The truth is that the owner of the 3.2 SS in the green car wanted a 2.8 SS but I only had one 3.0 turbo case and he graciously stepped aside for another customer.
That gesture got him quite a deal. I appreciate good people and reward them whenever possible.
Henry Schmidt
Ph: 760-728-3062
Old 07-12-2006, 04:50 PM
Send a message via AIM to fintstone
That 3.2SS sure is some eye candy! Do the twin plugs allow you to run it on premium pump gas?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-12-2006, 11:45 PM
Hi Stony
This engine does run on street gas. I have recommended a hybrid mix for track days.
A little up date: The car went to the track yesterday and ran 120 trouble free miles (60 laps) before loosing the clutch.
I guess a stock clutch just can't handle the power.
Who knew?
Henry Schmidt
Ph: 760-728-3062
Old 07-13-2006, 05:44 AM
Briana's Avatar
Send a message via AIM to Briana
Henry,
I sent you an e-mail requesting a quote to build this engine. When you have a chance please respond. Thanks!!
'14 Cayenne Diesel
Old 07-13-2006, 02:43 PM
