Which way to go...2.5, 2.9 , 3.0, 3.2
Hi,
I currently have a 72 T with the 2.4 MFI.. I love the MFI But I am tired of getting pasted in the streights by higher HP cars. SO do I go with the 3.2 swap like I was thinking? Or do I do something cool like a Hot 3.0 Or rebuilt /(find) my engine to a 2.5 or 2.7, 2.9 MFI I was reading about the 3.0 the is able to make about 220 hp That is really All I am looking for the 220 to 240 range/ It would be great to keep the MFI then I would not be limited to what I race in because I put to much engine in. Please let me know what you think , and what it take to do it, and the cost. This is kind of a sunday car ,but mainly a track car. Thanks
Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door |
One more Question, can my 2.4 MFI be changed to a 2.7 MFI
using my MFI and new larger P/C's?
FWIW, My otherwise stock '81 3.0 with Zenith's and early exhaust made 174 at the wheels, doing the math that's 205 HP at the flywheel and I've still got some tuning to do. I've got to believe with 964 or webcam 20/21 cams I'd be right around your 220 target. Just a thought.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
HI are you feeling lucky,really lucky, if so check the crankcase casting No' near the oil return tubes, you may have 7R cases, you will require the cylinder spigots bored out to fit the 2.7 cylinders, send the pump to the repairs to change the space cam for the 2.7 one and then watch the bank acc' empty, WHILE WE ARE HEAR WE MIGHT AS WELL!!!!!!!!!!!! good luck and post some pic' of the strip/build.
regards mike |
None of the above.
23/31 TB's and Smart Racing Bars and Elephant Bushings and Revalved Bilsteins. Anyone can go fast in a straight line.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
John,
Thanks for the help I do have bars, and 22/30 and HD Bilsteins, with poly bushing
Try not, Do or Do not
IMO: Short stroke, twin plug, MFI, 3.2.
Fast, powerful, reliable and period correct.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Mmmmm..
What Henry said, for me.. Kind regards David |
I saw this engine when I was at Henry's shop a few weeks ago and it looks even better in person.. This would be a great choice.
Henry - What is that hose you have connected to the breather cover?
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
That hose is a drain for the oil tank breather.
In the picture the breather (from a 91 Turbo) is on the right behind the air filter.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-06-2006 at 05:06 AM.. |
3 restos WIP = psycho
If you want FAST, Henry's suggested engine is the way to go. With the right work, 300HP is very doable. Not cheap, but bulletproof and FAST. What's not to love about a 70.4mm crank on 98mm pistons with MFI? You could spin it to over 7500 RPM and not break a sweat.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
300 RWHP. If this engine only makes 300 @ the crank I would be disappointed.
Yes, it runs on street gas.
Ooohhh..Henry..
Please...You must tell what you did inside to make that? Kind regards David |
I'll second that. Please post the specs to that 3.2SS when you get a chance.
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
98 mm QSC cylinders and JE pistons 10.3:1
930 Turbo oil pump w/ internal mod for max flow 911SC crank with knife edged flyweights 70.4 mm stroke lightened 911SC rods with ARP rod bolts and 928 nuts All rotating parts balanced to 0+or- .5 grams Supertec head stud kit 911SC heads (porting, twin plug and MFI injector port machining in house) 41 mm intake ports 39 mm exhaust ports Supertec MFI pump mods Supertec MFI Polymid fuel lines Supertec mag stacks 52 mm top 41.5 mm bottom. (52 mm velocity stacks and PMO air filters) Throttle housing rebuilt by Supertec 41.5 butterflies 40 mm ports. Supertec valve springs Tytanium valve spring retainers DC62 cams (thanks John) Taylor wires w/ Bosch connectors made in house Supertec RSR plug wire holders RSR spark plug connector holders BurnBros cast aluminum sump plate Supertec Gen II Twin plug distributor Getty Design amber shroud 1 5/8 headers. Sport muffler. MSD 6AL only one Two Blaster II coils Bosch CIS fuel pump ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-06-2006 at 05:10 AM.. |
I would rather be driving
Wow!
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Henry - What is your preferred MFI pump to use as a base for a motor like this? 2.2S, 2.4S, RS?
Deoxford - Thanks for starting the thread. I have a strong 2.2S in my car now and I absolutely LOVE the charactoer and sound of it, but I want more. I've been accumulating parts for a 2.6SS, but I am now thinking about a 2.8SS or 3.2SS. They all cost roughly the same to build I believe, with the 3.2 being slightly cheaper becasue the core costws less and doesn't need all the machining of an early sand cast aluminum case. I'm curious to see what other people's opinions are. Brooke
That said we can make any pump work. I used to race a 3.0 twin plug, hi butterfly engine that made over 300 hp on a stock 2.0E 010 pump. All MFI pumps move enough fuel to make 700-800 hp. Now the only question is how drivable will the engine be. MFI pumps have very little flexibility so when you tune them for power you loose fuel mileage. If you tune them to idle within a given CO range you might loose throttle response. The whole thing is a compromise. As with any performance modification when you gain in one area you loose in another. The prime example of this give and take is camshafts. A cam that gives you great top end will probably offer poor mid range transition. We are working on a version of the Falconer governor for application on the 911 engine. When completed it will offer a far greater range of adjustabilty. In fact it should be fully tunable throughout the rpm range. Don't hold your breath however, I have been playing with this for close to 20 years. It seems the Falconer governor has limited access to the front burner.
Henry can you PM me your cost to (re)build a 2.4T MFI to work on a 2.7RS style motor. 10:3 CR. S heads, S Cam, twin plug, for street/DE use. The MFI is on a running motor
Oh , and how long you need. Thanks
Robert Currently Porsche less (but the wife has 2) |
I just saw that 3.2 SS at the Dana Point Concours event, I didn't know Henry built it until I read this but that engine really caught my eye. Looks like one hell of a powerplant for an early car.
Would be great in my 914-6 #200.
VintageExcellence.com |
