Dennis these other scenarios are just for fun don't complicate your build by this just put the motor in crank for oil press and let it run a while for normal break in.
regards
Old 07-15-2006, 08:06 AM
Try not, Do or Do not
Henry Schmidt's Avatar
simulator
The Sim tester simulates engine function without the need to start it.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-15-2006, 08:14 AM
Insane Dutchman
racing97, you are probably right, but my byline pretty well describes my normal mode of operation.....just by way of example, I actually LIKE Henry's sense of humour and directness, I just wish he would actually say what he thinks once in a while....you know, not hold back too much.
BTW Henry, methinks you are getting my business for studs and machining for my engine (head work, rod work, balancing, boattailing etc....)
Anyway, not sure if there is a SIM here in Calgary, may well be, I will look around to see if there is, just as an option...
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 07-15-2006, 08:34 AM
Dennis
Boattailing ? Spend your money on something useful like RS graphics. You'll get just as much performance from a sticker.
Henry Schmidt
Ph: 760-728-3062
Old 07-15-2006, 08:44 AM
Insane Dutchman
Yeah, but how does the sticker stay on the inside of the case with all that oil splashing about?
Dennis
Old 07-15-2006, 11:51 AM
Henry,
Thanks for the info on the Simulator. I can see where this is of significant advantage for people building performance motors. Those NASCAR folks don't miss a beat when it comes to extracting every last pony.
Question. Well actually several. When you run a motor on the simulator, do you note the current draw before and after?
Have you found motors needing to be reworked?
How much HP is required to turn the typical Porsche motor?
Have you found a correlation with easier spinning motors and initial performance?
Lots of questions. Lot of things to be learned with a simulator.
Has Porsche ever specified a torque, HP, details of any kind for this procedure?
When you have time, sure, could you post a picture of a/your simulator, if it isn't a trade secret?
Thanks as always,
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-15-2006, 03:47 PM
ANSWERS IN RED
Originally posted by 2.7RACER
Henry,
Question. Well actually several. When you run a motor on the simulator, do you note the current draw before and after? YES, AMPS AND RPM. THE ENGINES GENERALLY INCREASE IN RPM THROUGH THE PROCESS
Have you found motors needing to be reworked?OIL LEAKS ONLY
How much HP is required to turn the typical Porsche motor? THE SIM IS 15HP
Have you found a correlation with easier spinning motors and initial performance? I DON'T DYNO THE ENGINES SO I HAVE NO WAY OF TELLING
Has Porsche ever specified a torque, HP, details of any kind for this procedure? I DON'T KNOW
Thanks as always,
Henry Schmidt
Ph: 760-728-3062
Old 07-15-2006, 04:05 PM
Thanks Henry, You ARE the Man.
DOUG
Old 07-15-2006, 10:04 PM
Still Doin Time
asphaltgambler's Avatar
Thanks for the info. Se I thought that 'SIM' would be an acronym for something deep automotive speak such as:
Spectacular - Ingenious - Motor - Measuring - Device !!
-OR-
Special - Instrument - for measuring - Motors !!
Old 07-16-2006, 07:53 AM
