John Brandt's Avatar
lime green o-ring...where did it come from?
I'm finishing up a project to fix a broken head stud and I have this green o ring left over that was not replaced as part of my V Reinz head set. Where did it come from?
It looks like one of the rings on the oil pump as pictured in waynes books, but
I DID NOT SPLIT THE CASE... so how could that be?
dimensions are
OD 34mm
ID 25.75 mm
wall height 5.88 mm
wall thickness 4.8mm
Old 07-16-2006, 05:00 PM
Wo ist die Rennstrecke?
DonE's Avatar
Engine oil cooler. There are two green o-rings near the top and a red one near the bottom.
Old 07-16-2006, 06:23 PM
abit off center
cgarr's Avatar
I have large green oh rings on my 4 oil return tubes
______________________
Craig
G2Performance
Old 07-16-2006, 06:53 PM
this one is somewhat larger than the oil cooler rings (even the big one) and has a square shoulder shape...so it's not from the return tubes
Is there an o ring like this associated with the Clutch?
AND
God Forbid, Is there any concievable way one of those oil pump o rings could get out without splitting the case?
Old 07-16-2006, 08:46 PM
I seem to remember having a couple of those around after my last 2 rebuilds. I don't know what they're for but I didn't seem to need them and there is no way that one could come out of the case.
-Andy
Old 07-17-2006, 07:16 PM
Super Moderator
cstreit's Avatar
Perhaps the clutch slave cylinder has a seal similar to a brake caliper seal? (I've never torn one down) I don't think that would come in a top-end set...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-17-2006, 07:21 PM
3.4 Bigger is better
88-diamondblue's Avatar
Virtually impossible for the oil pump seals to escape...
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 07-17-2006, 09:09 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
It might be the one for the distributor.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-18-2006, 02:08 AM
MBruns for President
JeremyD's Avatar
Throttle body o-ring?
Old 07-18-2006, 07:49 AM
Super Moderator
cstreit's Avatar
I thought the dizzy o-ring was somewhat oval... However as mentioned, your oil-pump orings can't escape if you didn't split the case...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 07-18-2006, 10:15 AM
JeremyD's Avatar
The TB gasket is the big one on the left
Old 07-18-2006, 10:35 AM
well, I took it up to my factory trained guy with 30+ years with 911, and he says its not from my engine.
we are going to re-insert tomorrow.
See you at Putnam Park this weekend!
Old 07-18-2006, 09:19 PM
