Wil Wil is offline
Piston Oil Squirters?
In doing a top-end rebuild, is there anyway to force solvent through or clean the piston oil squirters without splitting the case halves? Anyway to test them to see if they are freed up?
Old 07-24-2006, 01:50 AM
I can't think of anyway to plug all the openings you'd have to plug. I wouldn't want solvent in my oil system either.
-Andy
Old 07-24-2006, 08:21 PM
Banned
You will have to split the case, good luck, cheers, Ant.
Old 07-25-2006, 07:45 AM
I have got my case split but four of the squirters are blocked and I can't seem to force solvent down them using the pressure of the spray can. Any tips or good ideas would be appreciated.
Regards
Old 07-25-2006, 02:57 PM
Dadofour's Avatar
You may want to check out this thread
Piston Squirter Cleaning
Than
My Track Schedule
1984 911 Viper Green Track Car - Parted out to fund
1993 BMW 325is Spec E36 Race Car
Old 07-25-2006, 05:49 PM
Hi Dadofour I did and thanks for pointing me at it...
Regards
Old 07-26-2006, 12:55 PM
Super Moderator
cstreit's Avatar
Bottom line you'll need more pressure than a spray can will put out. 30psi I think is what opens then.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-26-2006, 01:00 PM
I never did get mine freed up. I ended up rplacing 4 of them. 3 wouldn't pass anything and one was very slow.
Case/Piston Squirters
Old 08-06-2006, 07:24 AM
Thanks the thread you pointed me at is very interesting. I hope mine will blow through with compressed air...
Regards
Old 08-06-2006, 08:46 AM
