Euro piston question
When you convert a US spec Carrera to Euro compression, do you have to change out the cylinders or just install the new pistons?
1985 M491 Carrera Slate Blue Metallic(fun car) 2001 BMW 325i (basic tranportation) http://jmforge.com |
Try not, Do or Do not
Just new pistons and adjust the maximum ignition timing.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Call in the AM and I'll check.
thanks, man.....just out of curiosity, what is the going rate for swapping out pistons asuming that there is nothing else wrong that needs to be fixed?
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Yes the 3.4 would be a better upgrade. I doubt you'd see even 10 HP with the euro pistons and you'll be in danger of detonation all the time. Like Wayne says...if your old pistons are ok why waste your money.
-Andy
72 Carrera RS replica, Spec 911 racer |
why would i have detonation probs? we have 93 super unleaded in Florida which is the same as 98 RON euro gas.
All 3.2 ECUs have a retard/ advance adjustment to deal with higher compression and questionable octane content.
I would agree that there is little to gain but the truth is how would anyone know the cost was too high without knowing the cost? Sometimes it seems like we have Porsche "whisperers" among us.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 08-01-2006 at 08:16 PM.. |
LOL!! True true Henry! Well met. The 'whispering' is all around us.
'71 S track car, 2.7L & Webers forever! |
curious about the gains.....factory specs tell me that i would go from 207 to 231hp since I already have the pre-muffler and sport exhaust ready to be installed...thats a pretty good jump for $800-1000 in parts cost. 3.4 9.8 to 1 pistons and cylinders run about $4,500, right?
Be careful with sport mufflers.
On a stock 3.2 we measured a 4% horse power loss with a Borla sport muffler. Horse power is a synergy of intake flow, cam, compression, ignition timing, fuel ratio and exhaust flow. Changing one may cost rather than pay.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 08-01-2006 at 08:48 PM.. |
