What could have cause this?
Hi All, I just pulled off the intake header and found the cause of my smoking exhaust. Upon inspection I notice that there was an oil leak in the intake system. What could have caused this? I checked all the hoses and there were no visible cracks or leaks in them. Most of the oil is in cylinder 1 and 2. The rest looks clean. IF the leak was in the intake system, then shouldn't the rest of the intake look the same?
What year and what induction/fuel system?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
it's a 85 Carrera. Motronics
up-fixing der car(ma)
I would imagine, among other things, that your valve guides are wasted. I am building a 3.2 (for sale) currently, I had 2 or 3 intake ports that looked like yours. My engine also had pistons/rings that were well out of spec.
Best Scott
Scott Kinder kindersport @ gmail.com |
If my valve guides are worn. Shouldn't I see oil on the valve stem or on the valve giude itself?
Thanks in advance |
Is there oil inside the intake plenum? Oil could be comming in through the breather. If the valve guides are leaking you won't see oil on them because they are washed with fuel by the injectors.
-Andy
72 Carrera RS replica, Spec 911 racer |
abit off center
Looks like carbon you find in an exhaust port? My 3.2 had bad guides too and would let the valve rock so bad it never sealed good. When you pull the valves out you will see how poor they were sealing. I also had some broken rings letting oil into the chanber
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
