deck height
I measured deck height tonight and got .055 (In inches) I measure a stock sc engine I have also and that measured .075(in inchs)
just go through what i am dealing with is a the following
98mm JE pistons Low compression turbo application(8.0-1)
3.0 sc bottom end with no offset on the rods
92 cc twin plug sc heads
What are you guys shooting for for deck height ??
Thanks so much for your time
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-28-2006, 08:54 PM
Jeff Alton's Avatar
Time to CC the set up and adjust the deck height for the target CR. It is fun...........
Cheers
www.turn3autosport.com
Old 12-28-2006, 09:45 PM
92cc heads I posted that info already
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-29-2006, 04:52 AM
Irrationally exuberant
ChrisBennet's Avatar
I shoot for no more than .040" (.1mm) per Steve Wiener's recommendation of .035-.040". I've measured higher on a stock 964 motor but your SC measurements seem kinda high.
Have you decked the case spigots yet?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-29-2006, 07:06 AM
Jeff Alton's Avatar
You still don't know what the CR wil be if all you have is the head volume. You might want to measure the piston dome voume as well.
Cheers
Old 12-29-2006, 09:17 AM
-Chris
yeah nothing was machined just a change in cylinders . can I run with out the shim??? Maybe a 609 locitite to prevent fretting??
henry had spec'd these out as 8-1 CR with stock sc heads(The Je pistons almost are flat with very little dome and valve releifs cut in them already) which is pretty much what I have nothing was machined on the heads other then chamfering and the twin plugging
I should restate I measured the 78 sc engine my garage(stock motor) and that measured considerably higher then mine..
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-29-2006, 12:18 PM
If you have the case apart you can have a local machinist "clean up" the spigot sealing surface. This will give you a nice "true" foundation for the cylinder+head+cam carrier stack and get you a better deck height as a bonus.
How are you measuring your deck height?
-Chris
Old 12-29-2006, 12:32 PM
dial cailper in 3 spots 120 degrees apart. Case is together now. I have read a bunch on this and allot of folks are suggesting that 1.2-1.3 mm is good to go for a turbo engine what do you think?
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-29-2006, 01:03 PM
Personally, I wasn't able to get good measurements using calipers.
-Chris
Old 12-29-2006, 06:42 PM
I will try the solder method.. I am not real concerned with valves hitting more so to control detonation Thanks guys oh and last question is why would that stock sc have higher deck height then what I have hear??
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-29-2006, 08:39 PM
