CBRacerX's Avatar
Reusing New Rod Bearings in Diff Rods?
Short Story:
Rebuilding 964 Engine.
Reconditioned Stock Rods
Installed Rods on Crankshaft with ARP Rod Bolts and New Bearings
Turns out the stock rods will not work with new pistons purchased
Purchased new rods with an identical big end (stock 964 crankshaft)
Can I use the new bearings that were installed on the stock rods?
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 09-01-2006, 10:21 AM
rod brgs
Sure, thats not a problem, even if the rods are new be sure to check for clearences, the dimensions on both ends are usually on the small side which tightens up the oil clearence,assume nothing check it or have ot checked before you assemble it.
Mike Bruns JBRacing.com
Old 09-01-2006, 03:28 PM
