ecm911's Avatar
964 Cam-timing questions
Hi guys,
My 964 is leaking from the crankshaft seal and the cam towers - so I am thinking about this project and have a few questions.
First off - special tools needed-
Do you need to use the special tool 9290 (counter-holding wrench) to remove the head bolt and more importantly is possible to counter hold w/o this special tool and get the proper torque (170 ft lbs)? I will get the special tool/bolt 9285 to remove the pulley.
Can the cam-timing be done w/o the special Auxiliary chain tensioner (9401) this are very very expensive? Can you use the actual chain tensioners?
Can these be rented somewhere?
I have some of the other tools needed or will purchase hem - cam sprocket wrench -9191, dial gauge & holder, feeler gauge.
Any advise or words or wisdom are welcome!
Thanks all.
Earl
78 SC Coupe
93 RSA (Gone)
Old 08-31-2006, 06:50 AM
Earl,
1. You definitely need the 9290 tool to remove, and more importantly, tighten the bolt.
As for the chain tensioner 9401, you can use a generic steering wheel puller. The actual chain tensioner is tooo weak.
See my rebuild page for pics.
964 3.6 Engine Top End
anthony
Old 08-31-2006, 07:30 AM
ecm911's Avatar
anthony,
Thanks for the reply.
And thats a great thread - I have it saved on my computer - it already has helped!!!
Any steering wheel puller will do?
Also any idea what the cost of the 9290 is?
Appreciate it!
earl
78 SC Coupe
93 RSA (Gone)
Old 08-31-2006, 08:21 AM
I think any steering wheel puller set would do. I would go to Autozone and look at the set to see if it would fit. Take your chain tensioner with you or do some measurements.
The 9290 tool is about $100. Pelican Parts sell them. I bought it (and most of my other rebuild tools/materials) from PP to support Wayne and the site.
You can easily resell the tool and recoup most of of the cost.
Old 08-31-2006, 08:54 AM
ecm911's Avatar
Anthony,
thanks for the info!
Have a quick question - it appears the cam tower weep/leak is from the left (top) tensioner cover.
I will confirm this is the only place , but if so can I pull the tensioner and replace the gasket w/o distrubing the cam timing?
TIA,
Earl
78 SC Coupe
93 RSA (Gone)
Old 09-12-2006, 05:39 PM
iangray100's Avatar
Hi, Does anyone know if the 9290 is the same tool for the 911 ( pre 964 ) as I can't find the 9290 on PP site?
I want the cam holding tool for a 964 ?
thanks
Ian
____________________
UK Surrey
Coupe 964 MY92 Tiptronic
To many toys to list..wife might be reading this ;-)
Personal thread: http://forums.pelicanparts.com/911-engine-rebuilding-forum/340187-964-3-6-full-engine-rebuild-over-uk.html
Old 01-15-2007, 03:23 PM
