Porsche Junky
What would Henry Schmidt do......
So....I pulled then engine on my cream puff 82 SC (2nd owner, 65k miles) to reseal it. (Had a gusher from driver side cam tower). When I pulled the valve covers I found 2 head studs in there....
So....my question is what can you do to a 3L to improve performance? Change outP & C's to allow for bigger cams? Stroke it? I have a set of 40 PMO's to finish this project...
1986 930 RUF equipped |
Does the car need to pass smog tests?
Is it going to be a street car? Whats your budget? A properly-cammed, 3.2 litre motor with PMO's and a proper exhaust can be made to run VERY well. ![]() Twin-ignition would be a big plus.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I'm not sure about the rest...but I guarantee that Henry would use Supertec head studs.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Porsche Junky
Well Steve...you pretty much hit the nail on the head for what I was considering...we do get 93 octane down here in Floriduh.....
But I think the cost would put me back to another 3.6 conversion....not that there's anything wrong with that...... ![]() Fint, the Supertecs are definitely on my list...
Try not, Do or Do not
If your budget is like mine, here's what I would do.
With 65K on the engine you can count on reusing the pistons and cylinders. Hoping they are Mahle Nikasil I would put valve pockets in your 9.3 :1 cis pistons, DC40 cams w/John's springs, port intakes to 39mm and install your 40mm PMOs and SSI exhaust and M&K muffler. 240+ hp Head studs are optional but I appreciate the plug. With an engine like this you could just replace the Delivar with steel studs. Now if you have a budget like the Pentagon, 3.2 short stoke, Carrillo rods, ported to 40mm, ty valves, DC80 cam w/Supertec valve springs and ty retainers, Supertec twin plug, Supertec stainless steel exhaust, M&K muffler, Aluminum flywheel, custom built MFI and of course Supertec head studs. 320+ hp.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-30-2007 at 07:23 AM.. |
Henry, what else can be said other than...
"you are THE picaso of porsche 911 engines" Bob
I live for 911 tweaks... |
Porsche Junky
Ask and ye shall receive...Thanks, Henry....
I need to call my congressman and see if he can get me in that mass appropriations bill.....
what are the cost estimates?
Henry,
Can you provide any general estimates on the total costs for the two engines? Sourced from you? thanks much marlin
Marlin Ness sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8 currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera |
E-85 sippin drunk
Re: What would Henry Schmidt do......
www.jbracing.com
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Re: what are the cost estimates?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
cool options and thanks for the plug as well henry. gotts get rolling on thise ss headers see ya!
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
