Try not, Do or Do not
Henry Schmidt's Avatar
What Are These Guys Looking At ?
The answer to this ever intriguing question is, a 2.7, Twin plug, Supertec engine.
The car is a beautifully restored 67 soft window 911 "S"
The project started some 4 years ago and was completed in time from Ventura.
Engine spec: 239 HP@6900 and 215 ft/lb @5500 on 91 octane ( bear in mind stock air filter, stock heater boxes and 40mm Webers)
2.0 aluminum case
2.4 "S" crank
twin plug, 2.7 "RS" heads ported to 38 in and 36 ex
Mahle 91 mm pistons 10.4:1
Supertec head studs
906 cams
Carillo rods
Turbo oil pump
shuffle pins
Dry film lubricant on all bearing
Internal regulator alternator
Turbo chain tensioners w/chain savers
40mm Webers jetted for street
Stock Porsche heat exchangers
And of course Supertec / BurnBros twin plug distributer.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-19-2006, 08:34 AM
rw7810's Avatar
Henry - I see they are using MSD coils with the Bosch CDI, didn't think you were supposed to do that?? Also notice the fuel pump in the ngine rather than up front by the tank.
PS: very pretty
Robert Williams
70' 911T
Old 09-19-2006, 10:13 AM
The coils are period correct Marelli, the CDs are 8 pin Bosch and the fuel pump is in the original place for the chassis.
Henry Schmidt
Ph: 760-728-3062
Old 09-19-2006, 10:22 AM
CBRacerX's Avatar
Very nice Henry! Great to see these old motors getting a new lease on life.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 09-19-2006, 11:28 AM
MBruns for President
JeremyD's Avatar
Very nice Henry - bet that car scoots!
Old 09-19-2006, 07:04 PM
Super Moderator
cstreit's Avatar
Heh heh...
Sometimes I feel like a crow, peering at all the shiny stuff. Nicely done Henry.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-20-2006, 06:07 AM
Constitutional Liberal
Turbo_pro's Avatar
Very, very nice as usual. I thought that 906 cams would be too aggresive for a street car. The dyno numbers say that just isn't true.
Who knew?
Henry, you are the man.
Old 10-07-2006, 08:58 AM
