Try not, Do or Do not
What Are These Guys Looking At ?
The answer to this ever intriguing question is, a 2.7, Twin plug, Supertec engine.
The car is a beautifully restored 67 soft window 911 "S" The project started some 4 years ago and was completed in time from Ventura. Engine spec: 239 HP@6900 and 215 ft/lb @5500 on 91 octane ( bear in mind stock air filter, stock heater boxes and 40mm Webers) 2.0 aluminum case 2.4 "S" crank twin plug, 2.7 "RS" heads ported to 38 in and 36 ex Mahle 91 mm pistons 10.4:1 Supertec head studs 906 cams Carillo rods Turbo oil pump shuffle pins Dry film lubricant on all bearing Internal regulator alternator Turbo chain tensioners w/chain savers 40mm Webers jetted for street Stock Porsche heat exchangers And of course Supertec / BurnBros twin plug distributer.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 09-20-2006 at 06:00 AM.. |
Henry - I see they are using MSD coils with the Bosch CDI, didn't think you were supposed to do that?? Also notice the fuel pump in the ngine rather than up front by the tank.
PS: very pretty
Robert Williams 70' 911T |
The coils are period correct Marelli, the CDs are 8 pin Bosch and the fuel pump is in the original place for the chassis.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Very nice Henry! Great to see these old motors getting a new lease on life.
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
MBruns for President
Very nice Henry - bet that car scoots!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Super Moderator
Heh heh...
Sometimes I feel like a crow, peering at all the shiny stuff. Nicely done Henry.
Constitutional Liberal
Very, very nice as usual. I thought that 906 cams would be too aggresive for a street car. The dyno numbers say that just isn't true.
Who knew? Henry, you are the man. |
