Poll: How to install rocker shafts?
Poll Options
Send a message via AIM to Purkinjefibre
Poll: How to install Rocker Arm Shafts?
There are a few alternatives concerning rocker arm/ shaft installation. One may choose to use RSR seals or not, but my question is simple; Did you use engine assembly lube on the shaft?
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 09-26-2006, 02:51 PM
I decided to try the dry method this time. I squirted oil into the holes on the rockers after assembly to lubricate them for the start up. So far so good.
-Andy
Old 09-26-2006, 04:00 PM
3.4 Bigger is better
88-diamondblue's Avatar
I used the RSR seals lubed with Dow Corning 111 and assembly lube on the rocker arm. Torqued to 16-18ft lbs. I read about the different ways of doing this and was the most comfortable this way. Also put drops of oil in the oil holes on the rocker arm after installed. Right or wrong? Not sure, but seems to have worked fine so far, No leaks.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 09-26-2006, 05:53 PM
Hi Andy, how many miles so far?
Michael, how did you prevent assembly lube being carried with the shaft from the rocker into the cam box?
easy
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 09-26-2006, 06:31 PM
I wasn't able to. I only put a very thin film on the inside of the rocker. No lube on the shaft itself, so assembly lube would only get on one side of the cam tower. Also the DC 111 on the RSR seals so I'm sure some of that was on the bore of the cam tower, but that is considered a sealant. I had to remove two of the shafts since I didn't get the RSR seals on two of the shafts. They came out fine and were tight after reassembly. I wasn't comfortable with the dry method when everyone recommends assembly lube for everything else.
Michael
2020 Honda Passport
Old 09-26-2006, 08:31 PM
if they're dry, they tend to get a better grip in the bore and are less likely to turn as you tighten the 5mm end. not that that means a whole lot. tight is tight.
206 637 4071
Old 09-26-2006, 09:40 PM
shbop's Avatar
I used assembly lube inside the rocker and on it's sides. Coated the shaft and other parts with engine oil. Used finger to coat inside of rocker shaft housings with engine oil. All twelve tightened without incident.
Jon
Old 09-26-2006, 10:38 PM
Irrationally exuberant
ChrisBennet's Avatar
Dry, dry, dry and then use RSR seals while wearing a piece of garlic around my neck to ward off the Leak Demons.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-27-2006, 05:11 AM
To answer the earlier question, my engine has about 1500 miles on it 90 percent on the track.
-Andy
Old 09-27-2006, 09:33 AM
Wo ist die Rennstrecke?
DonE's Avatar
Like any good torqued fastner, lube the threads and the conical ends, then torque them to spec. I use ARP moly (same as for the head nuts) which will ensure proper torque. Since I've been doing this, the shaft has not moved and no leaks.
Old 09-27-2006, 04:09 PM
