Dottore's Avatar
Head Stud Question
Can anyone tell me just from eyeballing the photos below whether the headstuds on my 1988 3.2 liter are the Dilavar studs that should be replaced???
Your replies are much appreciated.
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 09-26-2006, 07:04 PM
Test them with a magnet. Dilivar studs are non-magnetic.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 09-26-2006, 07:09 PM
Dottore's Avatar
...problem is the engine is already back together.
I had asked the shop to replace the head studs with Raceware studs as per everyones recommendations - but they tell me my studs looked "just fine" so didn't replace them. I only noticed from the photos that they hadn't been replaced.
Old 09-26-2006, 07:24 PM
Brando
quattrorunner's Avatar
They appear to be differant on top than bottom. I would venture that they are the dilavar on bottom and steel on top like from the factory.
Turbo powa!
1977 911s. it's cool
Old 09-26-2006, 07:33 PM
3.4 Bigger is better
88-diamondblue's Avatar
The bottom studs are epoxy coated dilavar. That is what mine looked like. Two broken on an 88 Carrera with 88,000 miles.
The black are dilavar and the others are steel
These are the steel studs cleaned and ready to go back in the case. Red loctite of course
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 09-26-2006, 08:45 PM
zbph10's Avatar
From the pictures they look just like the POS 4 broken head studs later SOB'ing Dilavars that I found on my motor that had been recently rebuilt.
The PO had it rebuilt and the shop left in the Dilavars and they lasted about 3 years and 30K miles.
Good luck
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 09-26-2006, 10:52 PM
They do look like Dilivar to me as well. I wouldn't panic however. First off there is not much you can do at this point. Second, I don't think the Carrera epoxy coated studs fail nearly as much as the SC studs. Remember you only see the failures on this site, not the thousands of engines with no failures. Odds are you'll be fine until your engine needs it's next rebuild.
Just keep an eye on them at every valve adjustment and try not to worry.
-Andy
Old 09-27-2006, 09:38 AM
Super Moderator
cstreit's Avatar
If the engine's never been torn down, they are likely dilivar. However the later 993 steel studs also came coated and if the engine had been done in the past, perhaps they were replaced with the 993 ones then...
I think the coated 993 studs came around about 1.5-2 years ago, prior to that they were uncoated, and some were fully threaded.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-27-2006, 04:11 PM
I don't know if the studs need to be replaced, but I tell you what does need to be replaced -- the wheels on that thing standing right next to your engine!!!
'79 911SC Targa -- "BLUVUDU"
'83 930 Coupe -- "TURBAUX"
Old 09-29-2006, 12:43 PM
You talkin' to me?
chancecasey's Avatar
The chickie? I dunno, she looks pretty hot for a circa-1970's babe. I'd have to see the entire chassis to be sure...
-Chance
'90 C2 Cab - Temporarily out of service
Old 09-29-2006, 01:33 PM
Dottore's Avatar
Yup. That's my mechanic's stand-up cut-out of Pamela Anderson.
Old 09-29-2006, 02:54 PM
You talkin' to me?
Ah, I mean late '80s babe. The swimsuit threw me off. Speaking of swimsuits...
http://wickedweasel.com/usd/bikinis/default.asp
Note - NSFW!
-Chance
Old 09-29-2006, 03:22 PM
Personally, I would have insisted they be replaced when the engine was out and apart. These engines are awesome but they were known to have problems in this area. Enjoy it!
Regards,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 09-30-2006, 09:28 PM
