(the shotguns)
2.4 S spec w/ 2.2 pistons?
I recall this being a suggested combo in Wayne's book but what kind of HP/torque would this give?
Anybody out there actually have this setup and if so how do you like it? Thanks, Erik
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
I have an engine that has the following: 2.2S case, 2.2S cylinders and pistons, and 2.4S crank and rods. It also has S cams and 2.4S MFI with plastic stacks.
I like it very much; however I don't get it to rev higher than 4000-4500 rpm in the city. The real fun with this setup is between 4500-7300 rpm!
'72T Targa w/2.2S MFI (sold circa 2010) |
