Eye of the Toiger
matty74's Avatar
Convert My 2.7 to 2.8 10.5:1
If I can, convert my 2.7 CIS to a 2.8 using Mahle Barrels and Cylinders (10.5:1)
I still am yet to get my heads machined, I guess 36mm
I have already invested in GE60's, webers, ssi's etc... My car wll not for racing at this point, it's a stock looking 74 911, but a bad ass street rod under the rear lid
1. Do I have to go to twin plug set up if i go with the 2.8 configuration (I assume if my compression is at 10.5:1 it will need twin plug and may take the mag case to the limit)
2. What possible modifications could I do to bring the comp down to around say 9.8:1 (like deck height) to make it a little more streetable?
Feedback apprciated
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 10-01-2006, 11:53 PM
You might want to take a look at this related thread. You might be pleasantly surprised, but you should verify the parts you have:
Dome Volume?
Sherwood
Old 10-02-2006, 12:49 AM
cfries's Avatar
matty74
I have a 75 Carrera with a 2.8L engine. It was done by the previous owner but I did rebuild it. I have 38MM intake and 46 Weber Carbs. I runs fine and I use it for street and DE sometimes. I am still working on the fine tuning. it runs a little rich and I'm thinking to go with a MSD ignition and get rid of the points. still researching that idea but I think its what it needs. Just make sure to add an external oil cooler (something other than the stock trombone), it will be much happier.
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 10-06-2006, 08:50 PM
Try not, Do or Do not
Henry Schmidt's Avatar
10.5:1 compression is overkill even with twin plug in a street engine.
9.5:1 compression in a 2.8 twin plug on street gas with DC60 cams, SSI and 40mm Weber or PMOs and you get 240 real hp. Just about the max for a mag case that you want to live.
2.7 40mm Webers, SSI, 10.0:1 comp., 906 cams 38mm port twin plug. 239 hp street gas,
2.8 SS slide valve, twin plug, 9.5:1comp., RSR sprint cams, 40mm ports, 1 5/8 headers, 300+ hp street gas.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-06-2006, 09:37 PM
Re: Convert My 2.7 to 2.8 10.5:1
Feedback apprciated
Matt
Hi Matt:
1) IMHO, you certainly do need twin-ignition when using the small-chamber 2.4-2.7 heads with the Mahle 92mm RSR P/C's unless you run 105 octane race gas. Anything over 9.8:1 needs dual-ignition.
2) These P/C's come in at 11.1-11.3:1 with these heads so the most you can reduce the CR would be to 10.25:1 and that requires some judicious machine work on the head to achieve that. Remember now, reducing deck heights make an engine MORE prone to detonate; you'll find more info on this in a recent thread about this subject.
No real-world shortcuts here but if its done right, these things really perform very well.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-06-2006, 11:16 PM
Eye of the Toiger
matty74's Avatar
Thanks for the info fella's, very helpful, you have helped making my decision much clearer.
I think at this stage I'm going to stay with 2.7 9.8:1 CR with JE's, dual plug is a bit beyond the budget, I think that an RSR spec build may be the build I'll do after this car.
Old 10-07-2006, 03:21 PM
