126coupe's Avatar
Twin Plug = More fuel??
Once I twin plug my 2.5L race engine will I be able to throw more fuel in there?
My guess would be yes, more fuel = more power??
Opinions?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 10-03-2006, 09:29 AM
Twin-ignition, in and of itself, doesn't require more fuel.
Twin-ignition does require different timing specs from idle to redline and this means the advance curve & total timing.
Air-fuel ratios should be 12.8-13.0:1 at WOT for best power for air-cooled N/A engines.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-03-2006, 09:36 AM
The challenge when trying to extract additional power has never been "more fuel". More air, or specifically, more oxygen is the difficulty because it is in the form of a gas (and in the case of air, only a 20% concentration) which takes up a lot of space relative to it's energy content. Big ports, hot cams, supercharging, and nitrous injection are all intended to get more oxygen into the combustion chamber; getting enough fuel is easy, metering it is the hard part.
regards,
Phil
Old 10-03-2006, 10:22 AM
To simplify what's been said already, twin plugging does nothing to increase the amount of air entering the engine. Since the amount of air is the same the amount of fuel should be the same as well.
-Andy
Old 10-03-2006, 11:05 AM
126coupe's Avatar
So twin-plugging my already "proven" 2.5L 10.2:1 Race engine, which after 40 hours of high reving (5,000-8,000) and showing no bearing or piston ring/cylinder wear , no detonation, no valve guide wear (race fuel only)is not worth the $$$$???
The only change I am making to this engine so far is to go from a 60 Cam to an 80 Cam.
To twin-plug or not is the question?
Opinions Please
28' Pace Trailer
Old 10-03-2006, 12:01 PM
DW SD's Avatar
twin-plugging is a preventative measure against detonation, which can destroy an engine in a hurry. Detonation is caused by high compression ratios and the use of non-sufficient octane fuels.
A larger cam should reduce your effective compression ratio. I would venture the opinion, while not an expert, that if your high revving race engine does not detonate currently (based on the condition of the engine provided) and you continue to use the same quality of fuel, that you don't need twin plugging.
Increasing the compression ratio will increase power extracted from a given amount of air and fuel, but the risk of detonation increases. Where the threshold of risk lies, I do not know. An expert will probably know. Henry or Steve Weiner would likely know that information from the top of their head.
1971 RSR - interpretation
Old 10-03-2006, 12:43 PM
sww914's Avatar
More correct air/fuel mixture, properly combusted, = more power.
More fuel= too rich, improper combustion, less power.
Old 10-03-2006, 04:19 PM
Opinions Please [/B]
Take a look at this: http://www.rennsportsystems.com/2a.html
Twin-ignition affords using less total ignition advance to perform the same amount of work and this results in more of the cylinder's gas pressure being utilized to make HP.
Further, ignition two flame fronts provides more efficient combustion as the pistons approach TDC. These lazy hemispherical chambers that have little or no natural turbulence or squish that create nice homogenous mixtures.
Aside from the financial hit by doing this, there is no downside and in fact, a great many benefits even for those using race gas.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-03-2006, 04:44 PM
High compression requires high octane 'race' fuel which burns more slowly. High rpm requires fuel to burn quickly. To burn more quickly, twin plugs can be used to essentially cut in half the time required for combustion since you have two flame fronts. Driveability is supposedly enhanced(per B.A.), but total power may not be.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 10-04-2006, 06:47 AM
If it hasn't been said directly or indirectly yet, twin plug ignition allows one to use higher compression ratios for increased volumetric efficiency without detonation or need for special, high octane fuel. This translates into more torque and power out of a given qty. of fuel - all good. If high octane fuel is available, increase the compression ratio for even more power.
Even with lowly 91 octane premium fuel available today, most modern engines have fairly high compression ratios. Current Porsches are what? 11 or 12:1?
Sherwood
Old 10-04-2006, 10:54 AM
Sherwood
964-993's actually range between 10.5-10.8:1.
The water-cooled models are slightly higher at 11.1:1 but with those water-cooled heads that afford excellent temperature control and their pent-roof chambers with centrally-located plugs, their flame propagation characteristics are almost ideal.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-04-2006, 03:05 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Twin plug engines produce more horse power/ torque everywhere, throughout the RPM range.
They (twin plug engines) will burn fuel more efficiently and therefore can use more fuel if all other things are equal.
Because you are burning fuel more efficiently the cylinder pressures are higher at all RPMs and higher cylinder pressures equal more power/ torque.
Imagine adding ignition timing to the point of near detonation. At that point your horse power is optimized.
Twin plugging allow for more effective ignition advance without detonation.
A simple test. Dyno test your twin plug engine with one set ( lower) of plugs shut down. Set the ignition timing to it optimum setting.
Now connect the second set and optimize the ignition setting. Rejetting is often required. Dyno test again. Your findings will be clear. More horse power at every RPM, with any fuel, guaranteed.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-04-2006, 05:09 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Did just that, about a 20 whp difference on my motor with the timing advanced for single ignition and than retarded for twin ignition...
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 10-04-2006, 05:53 PM
Home of the Whopper
So basically with twin plug you can reduce the amount of ignition advance without detonation, which results in more power.
And if you still get the same amount of air into the cylinder, and have more efficient combustion, you should be able to reduce the amount of fuel.
So more power and better fuel economy?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 10-04-2006, 07:46 PM
gumba's Avatar
What would be the typical total engine advance for a twin plug? On the Electromotive HPV-1 you can advance or retart from 3 - 8,000 rpm, what is the benefit/purpose of that.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 10-04-2006, 09:48 PM
On my mild Motronic street motor with 91 octane it is only 22°
Ralph
Old 10-04-2006, 10:00 PM
gumba's Avatar
HMMMMM? On my 3.4 race motor 10.5 comp, 46mm Webers, etc. I'm at 28d at 3,000 and down to 26d at 7,000 using 50/50 pump/100octane race. Is this too high?
Harold
Old 10-04-2006, 10:10 PM
Not knowing what cams you have, its hard to make firm recommendations, but 28 deg at 3K is FAR too much and thats costing you power as well as putting your pistons & rings at high risk.
Try:
10-12 deg at 1K
18 deg at 3K
25-26 deg at 7K.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-04-2006, 10:16 PM
gumba's Avatar
Thanks for the response. I'm using DC80 cams.
Harold
Old 10-04-2006, 11:16 PM
A good place to start for most race engines
5-7 degrees stactic
15 degrees at 2500
24 at 4800
28 at 6500
Henry Schmidt
Ph: 760-728-3062
Old 10-05-2006, 06:09 AM
