BReyes's Avatar
What is the difference in a 935 head v. 3.2 head 4 935 clone? I know housing is dif
What is the difference in a 935 head and a 3.2 head for a 935 clone? I know the housing is different.
Bernard
Old 10-07-2006, 01:20 AM
BURN-BROS's Avatar
The differences are minor;
Material(Rolls Royce spec) enhanced heat dissapation
Fully finned around spark plug areas
Special finned exhaust guide
No valve stem seal on said special guide
oil port that bisects exhaust guide to enhance lubrication and cooling.
twin plugged
The amount of aluminum used was more than the stock heads of that era. But I believe that the 3.2 has about the same amount of mass.
All of these things were to try and control heat at full boost for extended periods of time. I have heard that all of this was done specifically for the Mulsanne straight.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-07-2006, 09:24 AM
935 heads flow quite well, too............
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-07-2006, 10:09 AM
jdm61's Avatar
i have read that the SC RS used 935 heads and possibly the pistons too, but at a high CR obviously.
1985 M491 Carrera Slate Blue Metallic(fun car)
2001 BMW 325i (basic tranportation)
http://jmforge.com
Old 10-07-2006, 11:57 AM
We had a 911SC/RS here for a few months and those heads looked very close to 935 ones. I did not see the special oiling provisions to the exhaust valveguide that the 935 motor have.
The SC/RS has more CR than the 935's with a different piston design,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-07-2006, 02:25 PM
bergporsche's Avatar
935 head
911 3.0 RSR, white shell 911S 1974
911 2.7 Carrera 2.7 euro 1974
930 3.0 turbo 1976
Old 10-11-2006, 05:36 AM
BReyes's Avatar
Wim: Are those Ti valves? What size are they?
Forum: What are 935 heads flow numbers? Chamber CC? Port sizes? I'm surprised there is no flame ring groove.
Bernard
Old 10-24-2006, 01:25 PM
BURN-BROS's Avatar
It appears to have been modified. Weir had some Baby 935 heads that looked something like that....no sabe.
Burnham Performance
Old 10-24-2006, 06:46 PM
