964 low oil pressure solved, new question
Back at the end of August, while driving my 1990 C4 w/113k and no known engine work, the low oil pressure idiot light came on at a stop light and the pressure gage indicated a lower reading than normal. In the weeks the followed, I replaced the oil pressure sender, changed the oil, had the oil analyzed, and then pulled the pressure relieve valve plug/spring/piston assembly which controls the oil pressure. The piston was in good shape as was the spring and so I reassembled and poured the oil which had drained out while examining the assembly into a spent oil container. In the bottom of the pan I found a small ball of metal (~3/32") which appears to be brass, but which is slightly magnetic (ferrous).
The oil analysis did not show any abnormal results with the exception of 25ppm copper vs. the expected average of 11ppm. Once the oil relief valve was replaced, the oil pressure problem was solved. I am relieved that I was lucky to have a simple fix for a possibly major problem, but I am still concerned. I plan on having another oil analysis done in about 3k miles to check for any trends.
My primary question is what inside of the engine might contribute to forming this metal ball and was it formed at the end of the oil relief piston or is that just where is finally lodged? Does someone have a picture or drawing of how the relief piston works?
--tom
Old 10-10-2006, 07:08 AM
Bill Verburg's Avatar
First thing that pops into my head is piston oil squirter check valve.
Bill Verburg
Old 10-10-2006, 02:31 PM
Are those present in the 964 3.6 engine? If so, are they a steel ball bearing? What diameter? Where did the brass come from?
Anything which could be monitored or checked in order to try to determine if this is the case? I can do some further analysis on the metal ball to see if the core is something different...
--tnx
--tom
Old 10-10-2006, 10:26 PM
yes,
these are for a 993 but in the area where the squirters are the 964 and 993 are the same
there is a small round check ball inside of the cylindrical squirter body
Bill Verburg
Old 10-12-2006, 04:26 AM
Thanks for the diagram, but the 964 is slightly different in that it only has one oil filter. I cannot seem to find a similar diagram in my 964 service manual, at least not in the obvious place, and Adrian's book doesn't seem to have a diagram at the level of detail of your 993 illustration, so I'm guessing a bit...
In the single oil filter 964 system, does the oil flow though the filter on the way to the engine or on the way back from the engine? If it is on the way back, then the object could reach the pump and pressure relief valve straight from the tank.
If the object was from the piston squirter as you have suggested may be possible, wouldn't it have to pass through the screen on the oil pump? What is the hole size in that mesh?
--tnx
--tom
Old 10-12-2006, 06:56 AM
The 964 just connects internally where the 993 engine mounted filter console is, it makes no difference as far as your ? goes.
If a squirter pops out it goes directly to the sump. see the squirters in the crankcase pic?
Bill Verburg
Old 10-12-2006, 07:46 AM
Super Moderator
cstreit's Avatar
Unfortunately Bills estimation is the same as mine, the piston squirter is the only place I know of that would have a ball like that... It would also explain the higher copper content too, becuause when a squirter goes, the oiling to that main bearing drops dramatically and would wear out that bearing.. (Hence showing/leaving copper)
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-12-2006, 07:59 AM
So the current thinking is that it is probably time for a rebuild?
What kind of risk am I taking by continuing to drive in the current condition (e.g. how soon do I need to do the rebuild)?
Sorry if the following questions about rebuild options have already been answered elsewhere, please forgive me...
Assuming that I am fully capable of doing a large amount of work myself, but there is a question of time vs. money, and that the car needs some other attention (e.g. front gearbox axle seals are beginning to weep, etc.). What are the rough price differences in these options:
1. Should I just drop the car at Stoddards (about 3 hours east of me) and have them do what they feel is needed.
2. Drop the engine myself and ship it to Stoddards (or other suggested/reputable rebuilder) and then replace it when it returns.
3. Drop the engine and do the rebuild myself?
--tnx
--tom
Old 10-12-2006, 08:16 AM
Hi,
If what Bill and Chris is true I'd try to get hold of an old squirter (if possible, otherwise buy one) then open it to see what the ball looks like and if it's magnetic as you mentioned the 'item' is. If that matches up then the story is known. No idea though if those squirters have changed over the years nor if they are prone to failure.
Wonder if the oil pressure, at some point in time, could have gotten to high so that the ball was pushed out from it's location (or would it have to be sucked out) ?
Michael
Old 10-12-2006, 08:19 AM
Hi,
Long shot, but if you took out an oil return tube can you then inspect the piston squirters with a borescope ?
Michael
Old 10-12-2006, 08:21 AM
If the bearing is the copper creator then I wouldn't drive it one bit. If you do, the greater chance of damaging the crank.
To save cost I'd probably do #2, but lots of folks have done #3, but as we all know things always takes way longer than expected.
I'd try to price out bearing/gaskets/machining/valves/valveguides/yada yada, not to forget cost of potential 'new' tools to do the job versus a reputable rebuild.
#4 would be to get a replacement engine, though that one may have other 'fun' hidden.
Michael
--tnx
--tom
Old 10-12-2006, 08:32 AM
DW SD's Avatar
Tom,
I'm going to have my 3.6 case back from the machine shop in a week or so. I can take a look at the squirter to see if I can confirm that they are magnetic and what they look like.
I think the answer to your question has to do with for how long you can live with the car down.
I would guess option #1 would = $15k with all the ancillary items included (resealing the tranny).
2. You might shave several thousand $s from the bill. You might even look at sending the engine to one of our resident experts on the board (Steve Weiner comes to mind), shipping is expensive, but I bet he'd do a far better job than a dealership. Joel Reiser is close to you, too and is in the same boat.
3. you could probably do it for $5k to $8k, depending upon what you have done, if you seek more power, new cams, porting.
4. might be a good option, especially if you want to rebuild yours. You could buy a replacement (get a running one that you can test and document. Probably worth $6k to $8k. Rebuild yours and sell the spare when you are ready.
I've had my car down for the better part of a year, when I thought I would do a simple swap and be done with it in three months. My story is unique on one hand, but as it turns out not so unusal
Just one man's opinion.
Doug
1971 RSR - interpretation
Old 10-12-2006, 10:33 AM
Thanks Doug!
Tom- If you want to think about option 3, note that Bruce Anderson and Jerry Woods are giving their engine rebuild school this December. I won't be at that one, but may take Transmission again a couple of days after engine.
Also you are welcome to do option 2 & 3 right here with me this winter, if the distance isn't a problem... I am another 3-4 hours east of Stoddard. jmreiser@frontiernet.net
Old 10-12-2006, 11:52 AM
Originally posted by cstreit
Unfortunately Bills estimation is the same as mine, ....
Not sure how I shoud take that
Bill Verburg
Old 10-12-2006, 01:37 PM
Super Moderator
cstreit's Avatar
heh heh. Unfortunate for him is what I meant Bill. You're not getting sensitive are you.
I think it's a great idea to try and tear apart an old squirter and see if it matches... I don't know if you can get a borocope bent properly to look, but I know I'd try.
I don't think you'll get many more miles out of the engine before something bad happends if this is really the case... I hope it's NOT!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-12-2006, 06:45 PM
Hi,
Even if the borescope can't bend to see the squirter you could add a little mirror on the end. I'm quite sure that would be possible and the cost of a oil return line is peanuts in the engine build comparison. One guy at work have this model;
http://www.uniqueproductsonline.com/opticscope.html
Quite good and I think with a dentist mirror you would be able to see something.
Michael
Old 10-13-2006, 05:51 AM
Super Moderator
cstreit's Avatar
Makre sure you get one with a light.
Does anyone have a 964 case they could work out the angles from the oil-reurn tube hole and a piece of wire?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-13-2006, 06:48 AM
I've been reading this thread with interest and confusion. Are the balls in the squirters:
-a check valve to eliminate back pressure?
-a valve that allows oil flow through the squirter above a certain pressure?
-an object to shape the spray?
If they are a check valve, then the sprayer is probably still working as intended cooling and lubing the back of the pistons. However, is there a risk of damage to the oil cooling system from the pressure?
If they are a pressure relief, then they are still happily spraying the pistons, but at all pressures, not just above the valve's limit. No so bad either, unless the open valve lowers oil pressure somewhere else in the system causing wear.
Lastly, if the ball shapes the spray, then there is a chance the spray is not hitting the underside of the piston as designed lessening the cooling effect?
Now I'm wondering if in addition to the ball missing, the shape of the squirter after the ball was forced through it is also an issue. Either way it needs repair. Wayne's rebuild book explains that the squirters were implemented by Porsche in 1970 to reduce piston head cooling by a significant 100 degrees. These engines need cool pistons to survive the stress we put them under!
Here’s another quandary… Where’s the spring that holds the ball in the squirter? I’m guessing is stuck in the pump screen!
Out of curiosity, I'm going to visit Kelly Moss Racing to see if they have one laying about that is either disassembled, or I can hack open!
Old 10-13-2006, 07:16 AM
DW SD's Avatar
Don,
I'm no expert, but I've learned a bit recently.
The check valves are shut below a threshold pressure. So the pistons do not receive cooling oil at idle. I believe they open above 3.5 bars. That figure was provided by Steve Weiner off of the top of his head. In a 964 engine, the factory spec says 2.0 to 2.5 bars oil pressure at idle and above 5. bars at 2500 rpm. As was already stated, seems like it would bleed pressure if the ball is missing.
Good thoughts on questioning the shape of the resulting spray.
Doug
Old 10-13-2006, 08:36 AM
Super Moderator
cstreit's Avatar
Don,
The balls are a check valve. The sprayer stays closed untill a certain pressure. i thought it was 30 psi (2 bar)but it may be 3 bar....
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-13-2006, 10:05 AM
