GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Are 2.2 and 2.4 CV/Axles the Same?
Just as the Subject line says. Are the 2.2 CV Axles/Shafts that fit on a 901 gearbox the same as the 2.4 CV Axle/Shafts that fit on a 915 box? Are they interchangeable?
Old 01-05-2007, 06:08 AM
jluetjen's Avatar
The output flange on the trans is slightly different. The diameter of the bearing surface is 1 mm larger on the 915 flange then on the 911 (not 901) gearbox. It's a small thing to find a machine shop to turn down that 1 mm. I had to do this when I put trailing arms and axles from a '76 on my '69.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-05-2007, 01:14 PM
GotaT's Avatar
What do you mean by 911 tranny and not 901?
Old 01-05-2007, 02:21 PM
jluetjen's Avatar
The 901 transaxle was used through 1969 and used the push-style clutch. The 911 transaxle was used in '70 and '71. The gear cluster and most of the mechanicals were essentially the same between the two transaxles, but the 911 used a pull-type clutch similar to the later 915 transaxles.
John
'69 911E
Old 01-05-2007, 04:09 PM
