Questions about making plug wires
I must admit I have always purchased my plug wires already made up and need advice on making up wires.
The directions are vague so any advice would be helpful. the ends that attach to the plugs are fairly easy to assemble, my questions is how to crimp the metal ends to the moroso wires. I have the proper tool, but need advice on the crimping procedure.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Navin Johnson
Strip off about 3/4" of the insulation, leaving the spiral core exposed.
Fold this 3/4" piece of core back over the insulation, place this in the wire end, so that the spiral core is "down" (you want the core opposite the open part of the wire end) Then just crimp the end on, making sure you placed the boot on the wire before you crimp.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Re: Questions about making plug wires
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Re: Re: Questions about making plug wires
Less brakes, more gas!
I bought the pre-mademagnacores and they are a little short... what did your's cont if you don;t mind my asking...?
Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Why use radio suppression cables in a race car?
Sherwood |
Navin Johnson
Did you just buy a roll of wire and then cut to length?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
When I bought the twin plug system from JB Racing they supplied the cut to length wires with a margin for error. I will fine tune the lengths on installation.
thanks
quote:Why use radio suppression cables in a race car?
"for one thing, solid core wire can play havoc with EFI, and computer controlled ignitions/" I should have been more specific. Why install radio suppression wires on this race engine? I don't see any EFI yet. Typical MSD/Crane units shouldn't be affected by metal core plug wires which should last longer. BTW Mark, great detail on the engine. Regards, Sherwood |
Navin Johnson
MSD is pretty adamant about not using solid core wires, and in fact recommends supression type wires (see attached snippets from MSD). Im sure Crane is similar.
Also engine looks great, just lose the Summit sticker ![]()
Tim,
This is not the same application as a Chevy or domestic engine. Beru plug connectors already contain a resistor for this purpose. I have used SS core plug wires for over 20 years, 10 with a Crane ignition box; probably not too different from an MSD. Zero radio, ignition or pace maker interference. Sorry, I don't have a pace-maker.... yet. Sherwood |
If you think the interference from the wires will affect your MSD box, simply mount the box underneath your seat or in the front. You will have no problem with solid cores with this type of mounting.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
