126coupe's Avatar
Questions about making plug wires
I must admit I have always purchased my plug wires already made up and need advice on making up wires.
The directions are vague so any advice would be helpful.
the ends that attach to the plugs are fairly easy to assemble, my questions is how to crimp the metal ends to the moroso wires. I have the proper tool, but need advice on the crimping procedure.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 11-08-2006, 07:01 AM
Navin Johnson
TimT's Avatar
Strip off about 3/4" of the insulation, leaving the spiral core exposed.
Fold this 3/4" piece of core back over the insulation, place this in the wire end, so that the spiral core is "down" (you want the core opposite the open part of the wire end)
Then just crimp the end on, making sure you placed the boot on the wire before you crimp.
'69 911 GT-5
'75 914 GT-3
and others
Old 11-08-2006, 08:43 PM
Re: Questions about making plug wires
Where did you find those ends(spark plug ends)
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-09-2006, 06:47 AM
126coupe's Avatar
Re: Re: Questions about making plug wires
JB Racing supplied them, they are Magnacore
28' Pace Trailer
Old 11-09-2006, 07:06 AM
Less brakes, more gas!
euro911sc's Avatar
I bought the pre-mademagnacores and they are a little short... what did your's cont if you don;t mind my asking...?
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-09-2006, 08:59 AM
126coupe's Avatar
Best regards,
Michael
$18.00/each X12
28' Pace Trailer
Old 11-09-2006, 09:20 AM
Why use radio suppression cables in a race car?
Sherwood
Old 11-09-2006, 11:52 AM
Navin Johnson
TimT's Avatar
for one thing, solid core wire can play havoc with EFI, and computer controlled ignitions .
'69 911 GT-5
'75 914 GT-3
and others
Old 11-09-2006, 01:45 PM
Jeff Alton's Avatar
Did you just buy a roll of wire and then cut to length?
Cheers
www.turn3autosport.com
Old 11-09-2006, 03:13 PM
126coupe's Avatar
When I bought the twin plug system from JB Racing they supplied the cut to length wires with a margin for error. I will fine tune the lengths on installation.
28' Pace Trailer
Old 11-09-2006, 03:20 PM
Jeff Alton's Avatar
thanks
Old 11-09-2006, 03:23 PM
quote:Why use radio suppression cables in a race car?
"for one thing, solid core wire can play havoc with EFI, and computer controlled ignitions/"
I should have been more specific. Why install radio suppression wires on this race engine? I don't see any EFI yet. Typical MSD/Crane units shouldn't be affected by metal core plug wires which should last longer.
BTW Mark, great detail on the engine.
Regards,
Sherwood
Old 11-09-2006, 05:24 PM
Navin Johnson
TimT's Avatar
MSD is pretty adamant about not using solid core wires, and in fact recommends supression type wires (see attached snippets from MSD). Im sure Crane is similar.
Also engine looks great, just lose the Summit sticker
'69 911 GT-5
'75 914 GT-3
and others
Old 11-09-2006, 06:12 PM
Tim,
This is not the same application as a Chevy or domestic engine. Beru plug connectors already contain a resistor for this purpose. I have used SS core plug wires for over 20 years, 10 with a Crane ignition box; probably not too different from an MSD. Zero radio, ignition or pace maker interference. Sorry, I don't have a pace-maker.... yet.
Sherwood
Old 11-09-2006, 06:25 PM
BURN-BROS's Avatar
If you think the interference from the wires will affect your MSD box, simply mount the box underneath your seat or in the front. You will have no problem with solid cores with this type of mounting.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-10-2006, 06:41 PM
