JE Piston C clip install tool
I posted this in another thread today, but Randy Webb had the idea to repost it here for posterity:
For you guys who mentioned you had installing JE circlips, you might be interested in this. We fabricated a makeshift tool for installing them. It's basically a piece of 3/4" ID electrical conduit cut with a very slight bevel and ground smooth. Inside, we used a socket that just fits the conduit as a ram (13mm craftsman deep socking in my case) attached to a long extension. The clip is squeezed into the conduit on an angle and then placed flat to the piston. The socket extension is tapped lightly with a tack hammer to pop the clip in. On average, it took 2-3 tries per clip to get it in there. Easy and bloodless.
-Brian
Old 11-10-2006, 01:25 PM
3.4 Bigger is better
88-diamondblue's Avatar
I made a tool that works the same. Modified to fit JE Pistons. Great for saving fingers and other body parts.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 11-10-2006, 02:57 PM
