Price check.......
I've searched in vain but couldn't find anyting this specific.
From a top notch shop: For engine removal, complete ring job, head studs, complete valve job, all machine work, replace oil lines, returns and reseal, reinstall. $4K???? Parts seem to be in line but 30 hrs for all??
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
Stranger on the Internet
Sounds reasonable to me
Patrick E. Keefe 78 SC |
(the shotguns)
Sounds like a reasonable wintertime DIY job to me!
Does the valve job include new valve guides or just a regrind?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Thanks!
I hope you fare better than me, I need new exhaust valves as well, timing sprockets, chains, P's and C's, it became 7k real quick, and I'm not even done buying new parts yet.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
(the shotguns)
well if you don't have the space (and can not rent suitable space) then your decision is made in the DIY issue.
If $1k is parts you would also need to add machine shop fees to that to get a true DIY cost, so maybe that $3k is a bit less?
Sound fair to me. Check Wayne's rebuild book, it goes over labor and parts cost in detail.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Super Moderator
Very reasonable...
...the bottom end is quite simple and not that many hours in labor (or parts) provided there isn't machining required.
Thanks all. I just picked up Wayne's 101 book and should have ordered the Rebuild at the same time. I figured I'd have the shop take car of this job and I'll spend the time on the easier stuff!!
